WhiteIce | BIG PICTURE UPDATE!
Discussion in 'Project Logs' started by illvit, 14 Dec 2004.
How should the finnish on the plexi be?
Poll closed 9 Jan 2005.
  1. Clear blank
    1 vote(s)
    16.7%
  2. Matt(icy)
    6 vote(s)
    100.0%
  3. White under the plexi(mirror)
    1 vote(s)
    16.7%
Multiple votes are allowed.
  1. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    that's the spirit.
  2. illvit
    illvit What's a Dremel?
    14 Dec 2004
    Yes, I have experienced that the wood easily break. And thanks for the compliments. :)hehe: to the list sentence. )
  3. Poggie
    Poggie What's a Dremel?
    12 May 2004
    Would you people let THIS guy destroy the rainforest for this piece of.........uhm... You know what, this case can only be described as contemorary art. And if you want any suggestions. Try to make the parts symetrical, and a little bit bigger. If I were you I would use the inner case/skeleton of a regular case and dress it up with wood, try fur instead of plywood. I by all means necessary, use a 21st century watertank, you don't want to be like the swedish do you.
    P.S. Beklager svenske vitsen, men sånne ting ligger naturlig i norskt blod.
  4. illvit
    14 Dec 2004
    I'm appreciate all the respons I get. Here's a little backplate update. I will fill the "holes"
  5. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Good man... thank you for listening, we all make mistakes, but it is those who correct their mistakes that make good mods :D
    im glad to see you took my advice :D
    well done, looks 10000x better now imo
    keep moddin' (ohh isnt it just nice to please someone :D)
  6. illvit
    14 Dec 2004
    Allright, thanks!!
  7. Poggie
    12 May 2004
    Sorry about the harshness of my post it's just that I don't want you to make the same mistakes that I did. Attention to detail is all that matters. And now I see that you're making progress when it comes to practicality. The backplate would require a lot of finesse to make it look good. What I did with mine was just to clip off some of the excess aluminum, and sprayed it to match the color of my case. I honestly believe that your mod is a genuinly good idea, I just feel that you have rushed yourself a bit. (handsawing the plates was probably not a good idea. If want a good tip, mix coarse saw dust and mix it with glue (trelim), then use it like bondo. Don't worry about using too much because it is easy to file down, that way you get a smooth surface that still feels like wood.
    BTW er det ikke en mod på overklokking som er laget av tre med plaxi strimler i fronten og toppen.
  8. Sverdfisk
    Sverdfisk What's a Dremel?
    25 Jun 2004
    I've allready replied to your thread on Overklokking.no so you know my opinion, but actually I've changed my mind a bit now. The case looks good except the back, and imho I would try to make the front a bit smoother too.
    But the last pic you posted looks pretty good :thumb: :dremel:
    Poggie: Eg tror dette er samme fyren, illvit.
  9. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    the case might turn out great if you sand it. but you seriously have to work on your english, mate.. pay attension in class and don't just look up the words in a dictionary.
  10. Sverdfisk
    25 Jun 2004
    I forgot to mention sanding in my post.. Do that too.
    As for the english, we're the same age boy... Pay attension in class as Acid Burn says, you're going to need english later on anyway...
  11. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
    but dont sand too much or you'll have nonthing left :eeek:
  12. illvit
    14 Dec 2004
    Yes, I am going to sand the case to!!
    I have had good experience with the mixure Poggy is tipsing about, and that is what I have planned to do
    I know I have to work with the english. Even if I pay attension in class, it isn''t enough. Somebody who haves any tips about what I can do? Is it anyone who could be my personally teacher? :p
  13. Sverdfisk
    25 Jun 2004
    Looking forward to see the final result!
    As for the english, the best way to learn english (or any other language) is to use it alot and read english books amd stuff like that :thumb:
  14. Kverna
    Kverna What's a Dremel?
    6 Jun 2004
    or take a two year trip to england :rock:
  15. illvit
    14 Dec 2004
    Thank you! I have begun to read books on english, and I'm allready feeling that my english is going better.
    Here comes a backplate-update. I have now filled the holes with a mixture of treedust and glue:
    As you see in the picture the top sits a little bit skew in propotion to the rest of the case. So I have planned to file left a little bit: [​IMG]
  16. Sverdfisk
    25 Jun 2004
    Looks better now, no doubt about that :)
  17. illvit
    14 Dec 2004
    Thank you, Sverdfisk :D
  18. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    much better, will be un noticeable when you paint i imagine.
  19. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Really nice!
  20. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Keep it up mate :D Nice to see a modder such as yourself taking our input into perspective ;) Do you have any plans to put on any varnish type stuff once you've prepared the surface like ZapWizard has in his new project? :baby:
