WhiteIce | BIG PICTURE UPDATE!
Discussion in 'Project Logs' started by illvit, 14 Dec 2004.
How should the finnish on the plexi be?
Poll closed 9 Jan 2005.
  1. Clear blank
    1 vote(s)
    16.7%
  2. Matt(icy)
    6 vote(s)
    100.0%
  3. White under the plexi(mirror)
    1 vote(s)
    16.7%
Multiple votes are allowed.
  1. illvit
    illvit What's a Dremel?
    14 Dec 2004
    Hehe, thanks. I wil use that word from now :thumb:
  2. Poggie
    Poggie What's a Dremel?
    12 May 2004
    i give up on this species.
  3. illvit
    14 Dec 2004
    What?
  4. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    He means, that he is going to follow thid thread no more.
  5. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    don`t you have mroe picture of your wc :rock:
  6. illvit
    14 Dec 2004
    Ahh.. More picure will come tomorrow.
  7. Cowcharge
    Cowcharge What's a Dremel?
    27 Jan 2005
    Bondo and lots of sanding before painting can cover a multitude of sins... And sanding sealer!!! One of wood's best qualities is its forgiveness...
    Good luck!
  8. Cowcharge
    27 Jan 2005
    Oh, almost forgot... I assume you're going to use the plexiglas strips to show interior lighting, yes? That's where the uneven cuts will show up the worst... Perhaps some Bondo or thin pieces of wood trim to overlap the joint (but still leave some of the plexi visible for lighting) between wood and plexi would hide those first cuts?
  9. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    i really fell bad for saying this but i cant seem to get where or how this will turn out i hope the best for you but maybe all the money you spent )wood glue bondo and those got fans Why did you p;aint them ) you should have got a table saw and made some real good cuts but for a 15 year i have got to give you a 10 out of 10 when i was 15 i was to worried about girls and weed so i still hoping tangs come out great i just wished your dad had some better tools and was there to teach you how to use them :hip: :dremel: :clap:
  10. omicron
    omicron Baud.
    8 May 2004
    Havent been here in awhile (WoW is taking over my life), so:
    Hal - dumbass :p.
    Illvit - Ah, things were getting better too :(. I must say I'm starting to feel a bit worried again now..the paintjob doesn't look so good (what paint are you using anyway?)..you need to sand out all the lumps in your case, and you need to put enough paint on so as to make it look solid, so that you cant see the little grey marks behind it. I really dont like the look of the fans - and you really need to secure that res :blah:.
    Maybe you can rescue it..I really hope so. Keep going.
    (this typed at 7:20am, after playing WoW for 3 days straight - will come back in the afternoon and clear up any inaccuracies / leave me alone.)
    Mid
  11. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    :jawdrop: What did you do to that reservoir? Is it made from a bottle of MD 20/20?
    You got some kind of dust all over your components, dude I like the idea and I'm sure this can turn out great but you need to plan more before execution!
    Mod on :thumb:
  12. Sverdfisk
    Sverdfisk What's a Dremel?
    25 Jun 2004
    Long time no see.
    It looks pretty okey, but please sand it alot more. The color of the fans really isn't that important since they won't be seen at all propably...
    I think this can turn out great, so please people cut him some slack. I never thought this to be one of them forums where you can't post your work without someone with a greater postcount/egoboost/experience/whatever come and tell you that you're an idiot if you're doing it any other way than they say.. Please don't let this be one of them forums :sigh:
    Give him some time and it propably will turn out great :rock:
    Ps: Sry for ranting.
  13. omicron
    omicron Baud.
    8 May 2004
    Any progress on this?
  14. illvit
    14 Dec 2004
    Sorry that I haven't post here for a while. I didn't get post that someone had posted here, so I thought that nobody had post here. Anyway I have got one more sponsor: 3dfxcool.no And I got some dissafirmation on a blue lcdscreen from hammar.no
    ...and yes, I do know that I have to sand a lot more. The case look pretty rought now
  15. illvit
    14 Dec 2004
    Sorry, doublepost. By the way... I have much schoolprojects and that kind of stuff I have to work with, so I haven't so much time to work with the case now. So I assume that the next update with come once the next week.
  16. roll1
    roll1 What's a Dremel?
    21 Sep 2004
    It will be nice to see you back again.Glad you are still determined even though you have had a few problems.
  17. illvit
    14 Dec 2004
    Thanks. I got the lcd-display yesterday and have soldered it together. Update once tommorow.
  18. illvit
    14 Dec 2004
    Update as promised
    I got a nice post from 3dfxcool.no
    Content:
    dual 10cm chatods
    8leds
    ide-cabel
    I got some "rabatt" on a lcd-dispay from hammar.no . Unfortunately, I did exactly the same wrong thing as the other lcd-display I have soldered. :no: I am so unconsentrate when I sold :no:
    Men heldigvis gikk det bra denne gangen. Som du ser på det bildet over har skillsa mine blitt bedre.
    I hate to paint, but I have to do it :roll:
    I put the chatodes in the case just to check. The reason that the stripes and window look white is because it shines throught yellow mask-tape(and blue + yellow is, as you all know, green)
    The psu in the dark
  19. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Mate... please stop saying "spackle" or sparkle... your PAINTING!
    spackle is a type of filler made from wood
    you are painting... and i advise that you use filler over your case, and then sand it, THEN paint, as i see youve started painting without sanding at all....
    take care... looking good
  20. illvit
    14 Dec 2004
    Thanks.Fixed. I am "painting" the whole case now, and with that I mean that i filled ole those rawness and holes, to get a smooth surface.
