Who has their monitor turned 90 degrees?
Discussion in 'General' started by MrWillyWonka, 21 Feb 2008.
  1. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    A couple of days ago I had a PDF which would be best read as a full screen and to make the text readable I rotated my screen 90 degrees (Dell 2005fpw) and it's been like that since.
    I have a dual screen setup and now my left screen is at 90 degrees whilst the right is still on the standard position. Now I'm using the rotated screen for PDF reading and web viewing. Now that I really like it I'm leaving it like this for a while. I suppose having a widescreen monitor rotated is a bit more natural for reading since it is the same orientation as a book or A4 paper.
    Anybody else have it the same - providing their monitor has a rotation mechanism.
  2. kenco_uk
    28 Nov 2003
    I have mine set as landscape. I tried turning it to the same orientation as a boot, but it wasn't working out so well.
  3. Nexxo
    23 Oct 2001
    With 30", I don't need to rotate my screen. :D
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Yes, but how big is your screen?
  5. Orca
    Orca What's a Dremel?
    2 Dec 2005
    :sigh:
    I think ideally I'd like one of those, flanked by two 20 inchers in portrait, but otherwise no mine's always in landscape.
  6. Veles
    Veles DUR HUR
    18 Nov 2005
    Wouldn't make much difference on my 19" 4:3 :(
    I'll show you all soon! Muhahahahahaha!
  7. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Nope, I like to have two windows side by side on my 26"
  8. Firehed
    15 Feb 2004
    5:4 you mean. The 17/19" displays are closest to square.
    My 2005fpw is rotated at home, next to a 2405fpw in standard landscape mode.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Tried it, but I just got a stiff neck.
  10. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Im two thirds of the way to that now :hip:, unfortunatly 2007fps are getting harder to find. Its is the way to go though.
    Moriquendi
  11. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I keep mine at 45 degrees...
    ...because I'm special. :brrr:
  12. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I used to have a crappy 15 inch monitor that was pretty much useless until I turned it on it's side and used it for layers in photoshop. I could see about 5 more. It was worth it.
    :p
  13. Poisonous
    Poisonous Incestuious
    18 Apr 2007
    2x52" DLP projectors. Was only mine for a few hours though. :(
  14. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    I had my 24" Dell at my old job portrait for about 8 months or so.
  15. dragon2309
    dragon2309 techie
    28 Jul 2006
    nope, mine are landscape, they dont have the rotating mechanism anyway...
  16. MrWillyWonka
    25 Jul 2004
    Made me chuckle!
    I think I'm going to keep one monitor on portrait for a while, I haven't been arsed to actually move the portrait monitor closer to the landscape one so currently there is a 4" gap in between. Don't think I'm going to move it anytime soon. :)
    Only downside I guess is the masses of space I have to scroll down on this forum!
  17. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    My main monitor (22" Samsung) is the most unadjustable screen on the planet- it simply sits there and assumes you'll be too distracted by its shiny blackness to care about ergonomics. The laptop however is a convertible tablet so I stick it in portrait mode whenever I'm reading something or am using the touchscreen.
  18. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Sometimes I'll rotate my 2005FPW like yesterday when I was making a long smal banner with pictures..
    But most of the time it's in landscape mode.
  19. Bungle
    Bungle Rainbow Warrior
    7 Jul 2007
  20. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Horizontal at the mo, will be switching monitor at work to vertical once all data/crap is moved over to new laptop though. Makes SQL so much easier with the screen's turned!
