Graphics who uses 800x600?
Discussion in 'Hardware' started by Jaffar21, 14 Mar 2007.
  1. Jaffar21
    Jaffar21 What's a Dremel?
    14 Mar 2007
    I know most people these days use 1024x768 or even higher than that but does
    anybody here represent 800x600? I remember the good old days when my monitor was
    set to 8x6.
  2. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    I'd be surprised if you find anyone still using 800 x 600 on these forums. 1024 x 768 is about the norm for smaller 15" screens/laptops, but many are on 1280 x 1024 (as it's the native resolution of most 17"/19" LCDs) or higher.
  3. buchans
    buchans What's a Dremel?
    28 Jun 2004
    im sure some pensioners use it
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    My parents are still using 800*600 on their 17" CRT. If I ever change the resolution and forget to change it back, my father gets pissed. He uses 1024x768 on his 19" LCD at work though.
    When it's time to replace their PC, I'll get them a 19" or larger, and thus their usage of 800x600 will be eliminated. mwahahahaha
  5. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    I use It on my music pc as it makes it easyer to see from far away what songs coming next.
  6. nry
    nry Minimodder
    1 Nov 2006
    Car PC uses it and nothing else, only because the screen is 7"
  7. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    I run my Macbook and PC on my projecter at that res and it's fine for DVDs and AVIs.
  8. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    I haven't used 800x600 since I don't know when. 1280x1024 it is for me, and in games that resolution comes before AA/AF and even detail levels.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you've a laptop with 14" or less screen it may look better than messing with larger fonts and icons in Win settings, even though it's non-native. Win hasn't really got it right when it comes to enlarging menus, etc to suit easy reading at high res.
    That said, I re-designed my site for optimum at 1024x768 a while back and most sites suit that now.
  10. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
    my homemade laptop is 800x600.
  11. GoodBytes
    20 Jan 2007
    1280x1024 under Windows
    1600x1200 in Games
    Mwhhahaha the power of a really good 17inch CRT monitor ;)
  12. mattthegamer463
    26 Nov 2004
    Your 17 inch monitor supports 1600x1200? Thats madness! I've only ever seen 1280x1024 monitors at 4:3 ratio.
  13. GoodBytes
    20 Jan 2007
    Yea I know!
    The MAX MAX resolution where I touch the 60Hz refresh rate level is at 2048x1536 (it's kinda hard to find your mouse or read text).
    The rest is at 75Hz down to 1280x1024 at 85Hz.
    2048x1536x32 at 60Hz (text is starting to be a bit blurry at that level.
    http://pages.infinit.net/eps/desk1.jpg
    supported resolutions: (I skipped the wide screen resolutions)
    - 640x480 @ 150Hz
    - 800x600 @ 75Hz (the bad and weired)
    - 1024x768 @ 100Hz
    - 1280x1024 @ 85Hz
    - 1600x1200 @ 75Hz
    - 2048x1536 @ 60Hz
    :D
    If you still don't believe me, I can take a screen shot of the monitor with that resolution with great pleasure... actually let me do that now:
    http://pages.infinit.net/eps/desk2.jpg (curving is because of the camera)
    As you can see, you have Everest 2006, showing my current resolution (for you to know that I actually applied the setting)
    Side NOTE: That monitor was not cheap... I paid a LOT (450$ Can, and it worth every penny)
  14. GoodBytes
    20 Jan 2007
    NEC says that the max resolution is 1600x1200... they are correct (if you want to be able to read text and not have a flickering screen)
  15. mattthegamer463
    26 Nov 2004
    Wow. Very nice monitor. I'm coping with my IBM Thinkvision, which putts a modest 8ms and 1280x1024 max. Meh.
  16. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    i use 640x480 in games.. gives better accuracy coz the pixels are bigger..
    on desktop i use 1152x864
  17. Krikkit
    21 Jan 2003
    Interesting desktop res. choice there Rage.
    Personally, I use 1920*1440 day-to-day, as it's the max. resolution which can be done at 75Hz on this monitor, although it'll do 2048*1536@60Hz if needs be.
    The real problem I get with this is some little ghosted lines next to sharp colour changes (like at the side of this forum, going from grey to blue), from the DVI->D-sub convertor on this graphics card. It just doesn't like high-bandwidth at all. I'd change it for a proper cable, but no-one makes a decent one (at least not one I've found). :p
  18. Anator
    Anator What's a Dremel?
    26 Feb 2004
    I use 800x600 to play counterstrike as it's easier to get a headshot. But thats it :p
    Use 1024x768 for everything else with the odd game in 1280x960
    (17" CRT and yes, mine does 1600x1200 as well)
  19. ijakings
    ijakings What's a Dremel?
    23 Sep 2005
    I use the same as rage. 640x480 in most games and 1152x864 in desktop. My Cheap £40 LCD only goes up to 1024x768 and i use that at either that, or 800x600 for my Samurize Config.
    My monitor arm actually cost more than the monitor lol.
  20. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    You'll probably find there are more people using 800 x 600 than you think.
    Just think, what resolution does WinXP default to on a new install.
    ALL tech savvy people will then take it higher etc, but there are a lot more PC users that are not tech savvy.
    Its always been a consideration when designing a website for the 'general population'
