Disaster Whoops, watercooling
Discussion in 'Modding' started by chiggyman, 19 Sep 2004.
  1. chiggyman
    chiggyman Banned
    18 May 2004
    Simple disaster
    Installed watercooling, ran fine
    Put side window back on, bent one of the pipes to tightly. Mum is like isnt that pipe supposed 2 connected. (It was powered on) Its spraying plenty of distilled water on my ATX power connector and northbridge. O well, new motherboard :baby:
  2. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    and mom pays for the new board? :hehe:
    Nah, that is what i refer to as "bad luck"
  3. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    did the tube break in half or come off the barb?
  4. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    ahh.. so all those theories about distilled water not harming your computer is wrong eh? :p
    well that sucks, luckily all my leaks have been away from pc parts.
  5. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    The deionised water can pick up ions...rather useless, eh?
    It's distilled to get rid of the crud, not to protect your hardware.
    Next time, make sure you install the watercooling properly, and leak test!
  6. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Lol use that 3M stuff that cost $200 a gallon. it does not conduct electricity.
  7. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    ooo which stuff and does it cost sooooo much :jawdrop:
