Education Why are batteries refered to as flat?
Discussion in 'General' started by steveo_mcg, 19 Apr 2010.
  1. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    As title, why when a batter reaches the end of its life do we call it flat? Had a look on google but can't see anything, so with the huge pool of knowledge round here, what you got?
  2. smoothie
    smoothie What's a Dremel?
    28 Jul 2007
    I've never heard that term before (I'm in the US). We call them "dead" batteries.
  3. xrain
    xrain Minimodder
    26 Jan 2004
    Because they become like a flat soft drink? no zip left in them...
  4. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    This is just a guess but I think its because if you test a battery that has no power then the multimeter will just stay "flat".
  5. specofdust
    specofdust Banned
    26 Feb 2005
    Just a lowly educated guess, but I'd assume because on an oscilloscope electricity makes spikes and curves, but when a battery is out of juice the line will be flat.
  6. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    +1
  7. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    The line will be flat even for a charged battery, only a changing voltage will produce spikes and waves on an oscilloscope.
    Moriquendi
    mvagusta and Prime like this.
  8. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Because you've run them flat. Can't get a blip out of them.
  9. Prime
    Prime What's a Dremel?
    19 Aug 2009
    +1 to Moriquendi.
    The term probably originates from the heaviside function which is used to model current or from the early electro-chemical cells which would probably have gone dry or stopped fizzing (producing hydrogen) and hence gone flat
  10. xrain
    xrain Minimodder
    26 Jan 2004
    Even if you put a dead battery on a multi-meter, It will still output a voltage. For example, a charged 12 volt car battery will read around 12.5-13.5 volts on average, and <11 when dead.
    And Moriquendi is right on the flat line on the oscilloscope part, although its possible the voltage might also fluctuate when discharging battery also. But the only kind of power source that will give a non flat reading on an oscilloscope would be AC power, since it alternates between negative voltage and positive voltage. And since no batteries store power in AC the point is moot.
    I still think it has to do more with the connotations the word flat has, because you can have a flat tire, or a flat can of beer, or live in Flat, Alaska... None of which are good, but the most common way to refer to a uncharged battery would to call it dead.
  11. steveo_mcg
    26 May 2005
    Wheres John when you need him, he can perhaps explain why he coined the term.
    I'd say in the UK flat is more common than dead though.
    mvagusta likes this.
  12. knuck
    knuck Hate your face
    25 Jan 2002
    Maybe it's just slang. Just like here. We say "la battery est à terre", which literally means "the battery is on the ground"
    French (real ones) find it really funny when we say that... Meh
  13. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Batteries don't really truly die, not for a very long time anyway, they just drop out of a useful voltage range, which is why you can take the 'flat' batteries out of a high power device, like maybe an Xbox controller and it will still work in a lower demand device like maybe a TV remote, Alkaline batteries start at 1.5 (usually actually like 1.6V) and the lowest I've ever measured was about 0.5V on an alkaline battery that had been in storage for ages
    An Moriquendi is right, an oscilloscope will only show a waveform for AC, Sawtooth etc.. voltage types, DC is a flat line all the time
  14. capnPedro
    11 Apr 2007
    Never say never always - DC ripple can be a serious problem!
  15. Moriquendi
    3 Nov 2005
    It's called DC ripple but in actually it should be described as an AC waveform superimposed on the DC voltage, DC is DC and will always give a flat line, if it doesn't then it's not strictly DC.
    Moriquendi
  16. capnPedro
    11 Apr 2007
    Very true, but it sucks when it shows up in your DC waveform while you're still set to DC coupling. Time to bust out some smoothing caps, anyway.
  17. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    That's a hell of a tautology there, you basically said "we call them that because we call them that"!
    I call them flat because **** YOU ESPERANTO, I LIKE MY LANGUAGE ARBITRARILY ILLOGICAL
    badders, October and CardJoe like this.
  18. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    They're called flat, because yo' momma sat on them.
    Done.
  19. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    We call them flat because they are not not flat anymore. :thumb:
  20. Moriquendi
    3 Nov 2005
    Yup, I think that the way a 'scope works is that with AC coupling there's a cap or a transformer in series that blocks any DC component while DC coupling goes straight through so it'll show any AC component as well.
    Moriqendi
