Cooling why are my temps so high
Discussion in 'Hardware' started by 3N1GM4, 24 Jul 2003.
  1. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    i have a Innovatek kit, and my ambient is "32*c" and idle it is "48*c"
  2. Cheese
    Cheese Doc
    6 Oct 2001
    What's your processor, how're you measuring the temps, have you measured the temps with the system air cooled in the same fashion and know these temps to be high, and what's your load temp?
    Rob.
    p.s. likely causes of poor water cooling temps are; air in the system, bad block fitting, constriction limiting water flow, bad radiator placement/cooling...
  3. 3N1GM4
    23 Jun 2003
    my processor is a Pentium 4 2.4ghz, im using CPUCool, and using the onboard sensors, and my mobo is a MSI 864, when i measured the temps w/ my standard p4 heatsink they were around the same degrees, as with the watercooling kit, and when im gaming, 98% load, it gets up to about 52*c
    there are a few air bubles, that collect in the top of my radiator, and they come out every like 10-15 mins. the block fits nicely, im using artic silver 3, and the radiator is getting alot of air, though i do have it "pushing" air through, it is getting good flow
  4. 3N1GM4
    23 Jun 2003
    err :confused: bump
  5. Supercool
    Supercool Gone.
    31 May 2003
    :nono: thats no good, try shaking the rad to get them out.
  6. 3N1GM4
    23 Jun 2003
    that is what i do, it looks like the pump is pumping water and in the water is VERY tiny bubbles, that eventually end up collected in the radiator, is there any way i can fix this?
  7. Haddy
    Haddy World Domination
    22 Jan 2002
    I dont know enough about the p4 processor to know if the onboard sensor is good enough to get an accurate temp reading....Most of the time without the heatsink's fan there to blow cold air onto / around the cpu the sensor will just read the warm air around the cpu temp instead of the actually core temp....
    Do you happen to have any pictures of your rig? Basicly it can be a billion different things so the more info we have the better.....
  8. 3N1GM4
    23 Jun 2003
    1398342003 Ubermodder
    2 Sep 2002
    Your reserivor should be at the physical top of the loop. Do you have extra hose? If so, then put the pump/res in a drive bay.
  10. 3N1GM4
    23 Jun 2003
    i cant really move my pump to the top either, that is the problem, i might look into buying bay res, but till then any suggestions?
  11. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I've used some course aqua filter sponge in my res to trap any air bubbles in the system and has done the trick. Point of note, the res is at the highest point of the system as Haddy suggested.
    I use a temp probe directly touching the core and gets a reading of 32C Idle with a room temp of 25C. This is with a fan running at 145rpm.
    Haven't finished all the testing as this is a new build. Good luck in your quest.
  12. wda97c
    wda97c What's a Dremel?
    25 Jul 2003
    I would see if there is an update to your MSI drivers. I have an MSI NForce2 and it was giving me temps of 65C on my Athlon 2400+ (wil an SLK800 and 80mm 85cfm fan oni it!), updated the bios to version 3.5 and it dropped my temp down to 29C. I didn't quite trust that so I bought a Hardcano 9 and put the temperature sensor on the bottom of the CPU and it is actually at about 35C.
  13. 3N1GM4
    23 Jun 2003
    illl deffinatly look into updating my bios then
    thanks for all the help
  14. 3N1GM4
    23 Jun 2003
    quick question when i use CPUCool it says 48* but when i use the MSI Prog, it says 52*
    n e 1 know why this is?
    edit, got all the air bubbles out, and it dropped my temp 3 degs... any other suggestions?
  15. mushky
    mushky gimme snails
    24 Mar 2003
    if your computer is stable and running at a good speed then dont worry too much about the temps.
  16. Cheese
    Cheese Doc
    6 Oct 2001
    TBH if that's your attitude then extreme kooling probably isn't the forum for you :p
    Rob.
  17. [GiB] Spawny
    2 May 2001
    The only reading I use is directly form the core. Many control panels have probes included in there function. Also some have a LCD for a visual reading.
  18. 3N1GM4
    23 Jun 2003
    does water wetter really add that much difference???
  19. Cheese
    Cheese Doc
    6 Oct 2001
    No, it's mainly there to prevent corrosion.
    Rob.
  20. 3N1GM4
    23 Jun 2003
    do the old innovatek wate block suck or something, i am thinking about ordering a geforce4 block and then getting a new cpu, and northbridge clock...
    like danger den ones or something
