Other Why do I get the device connected/disconnected noise when the downstairs light is turned off?
Discussion in 'Tech Support' started by oscy, 3 Jul 2017.
  1. oscy
    oscy Member
    22 Sep 2011
    The kitchen light.
    And when I turn off the (regular) fan when it's plugged into the same extension as the computer.
  2. oscy
    oscy Member
    22 Sep 2011
    Ok it's the kitchen light doing it for whatever reason.
  3. Pookie
    Pookie So this is permanence, love's shattered pride.
    4 May 2010
    That's a weird one, is your power supply a fancy one that has a USB connection direct to the mobo for monitoring? Does it do it if your pic is plugged into the wall rather than an extension?
  4. oscy
    oscy Member
    22 Sep 2011
    Just a regular one that's plugged into the socket in the wall.
    And this hasn't happened for weeks since, but at some point it'll happen again for no forseeable reason.
  5. Corky42
    Corky42 What did walle eat for breakfast?
    30 Oct 2012
    What device is connecting and reconnecting?
  6. keir
    keir S p i t F i r e
    5 Oct 2003
    Are you using homeplugs/powerline adapters?
  7. oscy
    oscy Member
    22 Sep 2011
    Nothing? Don't know.
    Don't know the brand, if it has one.
  8. wolfticket
    19 Apr 2008
    I've had an HDMI connection that disconnects and reconnects briefly when you turned on desk fan that was plugged into the same extension lead.
    I would guess it's some sort of electrical surge/noise/interference that is being generated by the appliance when it is being turned on/off and it is affecting the PC/device because they are connected to the same extension.
  9. Corky42
    30 Oct 2012
    It should be recorded in the Windows system event log, it may not help to know what devices it is but at least it will help narrow it down a little.
  10. oscy
    oscy Member
    22 Sep 2011
    I looked that up, and I'm guessing I'm wanting to look at Hardware Events, and the answer is 0 events.
  11. keir
    5 Oct 2003
    So that's a yes?
    Maybe as simple as, the power is briefly making the network disconnect.
    Try and speed test.
    The another one with someone flicking the kitchen light on and off. See if there is a difference.
  12. oscy
    oscy Member
    22 Sep 2011
    It's an I don't know, it's just a regular blank ol' extension plug.
    My network speed? I'm having no internet problems.
  13. spolsh
    spolsh Member
    4 Feb 2012
    When he said homeplugs/powerline adapters, he meant network plugs through the electrical wiring, not your extension cord.
    It could well be a wiring issue in the house, at work our CCTV monitor goes off whenever someone walks through the back room (triggering automatic lights).
