Rant Why do makers of memory do this ?
Discussion in 'General' started by mayhem, 23 Oct 2008.
  1. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    Oky like every one you buy memory with a heat spreader to help aid the removal of heat is that correct ?
    So then why do all makers of memory then suddenly go stick a warranty sticker on that says "Do not remove or you will invalidate you warranty" right across the heat spreader. This is making the point of havening a heat spreader useless because you have introduced another factor to aid the none removal of heat. The stickers you all use are not made of metal they are not thermal conductive in any way yet the sticker size nearly cover 1/2 of the stick or in the case of XMS nearly all of the stick when you include the Big XMS 2 sticker.
    Now i fully understand that if people have side windows its a good way of advertising the memory but again its a pointless and fruitless exercise because you in one hand trying to solve a problem and then in the other adding to the problem.
    Why don't you instead Etch you name on the metal and use some other form of sticker but not on the product it self. It feels as though your being givin in one hand and taking away with the other.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    your really ranting about nothing mate.
    a little paper sticker isn't going to effect alot.
  3. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The paper is so thin it doesn't really do anything.
  4. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Are you really running your memory so hot that the difference between stable and unstable is that sticker? If so just take it off.
  5. wolfticket
    19 Apr 2008
    Because heat spreaders on memory are largely pointless and mostly used to make memory look cooler so they can charge more for it?
  6. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    personally i agree, but it follows that if they make it look cooler by putting the spreader on, why put a fug ugly sticker over it? that you can't remove without voiding your warranty.
    would you by a lambo with a big 'warranty void if removed' sticker on the bonnet?
  7. badders
    badders Neuken in de Keuken
    4 Dec 2007
    They're Heatspreaders as opposed to Heatsinks. They even the temperature load across all the RAM IC's, so that no one IC gets overly hot.
    The higher-end stuff, such as Corsair's Dominator RAM, come with devices that are more like Heatsinks, though they also perform the same function as Heatspreaders.
    I agree with LeMaltor - if you're running your RAM ragged, so that cheap heatspreaders no longer cope, then it may be time to upgrade to something with heatsinks.
  8. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    I would totally take the damn sticker off, and then arrange them neatly on your forehead.
  9. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Heatsinks are heatspreaders, and heatspreaders are heatsinks. If anything all you could say is that heatspreaders are small heatsinks. There are plenty of chips in your pc that use part of the pcb as a heatsink, which is alot smaller than a ram heatspreader, but it's still a heatsink.
  10. naokaji
    naokaji whatever
    8 Dec 2006
    Ram doesnt need any sort of cooling anyway if you run it at sane volts and if you go beyond that then you are far better off with a fan than any sort of heatsink / spreader.
  11. Burnout21
    9 Sep 2005
    +1
  12. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    Stop posting.
  13. Burnout21
    9 Sep 2005
    on what grounds do you have to tell me that.
  14. dom_
    dom_ --->
    4 Jan 2004
    These ones.
  15. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I don't often, really, laugh out loud when on the internet, but that did for me.
  16. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I see what you did there! But I'm not falling for it!
  17. Burnout21
    9 Sep 2005
    Pure class! love it!
  18. TX297
    TX297 Hey guys have you heard of seenly?
    28 Oct 2003
    Yes, but considering
    I don't think it was intentional.
  19. iggy
    iggy Minimodder
    24 Jun 2002
    BUMS!!!!
  20. mvagusta
    24 Dec 2006
    So does that mean the best way to cool a hot ic is to not have a heatsink on it, but just a fan blowing a cool breeze on it?
    Heatspreaders affect ic's in the same way as a heatsink, the're both designed to absorb and dissipate heat away from the ic, so they both give the same effect, just one is normally larger than the other. If you want further cooling, then using a fan on a heatsink or heatspreader will give much better results than just using a fan on a bare ic. If i had a dollar for everytime people get thier stuff mixed up, such as heatspreaders, heatsinks, then, than, thier, the're, affect, effect, etc, i'd be rich.
