Linux Why does linux never work for me :o
Discussion in 'Software' started by orb, 22 Nov 2005.
  1. orb
    orb satisfying.
    23 Dec 2003
    Okay, my linux ubuntu cd's arrived today. It came with a live CD so i thought i can see if i can get the internet, and apparently the 5.10 release came with ndiswrapper, so i thought it would be farely easy to get the internet, i was wrong :( .
    After around 30-45 minutes of playing with the network settings i still haden't got anywere..
    I've checked ndiswrapper site but its still rarther complicated, does anyone have a very easy guide for a extreme noob to linux like me to get my wLAN to work?
  2. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    Is there no linux drivers for your Wlan card?
    Im a linux noobie really and i got my wlan working with slackware.
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Including the make/model/chipset of your wlan card would be a good start...
  4. orb
    orb satisfying.
    23 Dec 2003
    its a Yakumo QuickWLAN USB . Not sure on the rest :(
  5. simon w
    3 Nov 2003
    Your answer is top of the list
  6. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    For me it's the opposite. Networking only works on the live, ndiswrapper doesn't work at all for me in the install. That's why I use FC4 now. Works perfectly.
  7. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    sorry to hijack a thread, but i have a wg111t usb wi fi adapter, and have uuntu 5.1 as well, nut have no idea on how to install it, ive looked around but it seems really complicated, any help
  8. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Unfortunately I've never had a problem w/ wifi except getting wpa to work. But if you search or start a thread at ubuntuforums.org, you'll most likely find an answer.
    Sorry I couldn't be of more help
  9. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    Just to be clear on what ndiswrapper is:
    ndiswrapper allows you to use wireless drivers for windows in linux. If ndiswrapper is required to get your wireless card to work, you must first download the windows versions of your network interface's cards.
    Once you have downloaded the files into a folder, say... home folder/drivers/wireless/ and we'll pretend your driver file is driver.ini (it will be something else, but this is just an example)
    open up a terminal and type:
    sudo ndiswrapper -i ~/drivers/wirelss/driver.ini
    Now to see if it installed properly, list the ndiswrapper drivers:
    ndiswrapper -l
    ^lower-case "L"
    It should say something similar to:
    "name of driver" driver present, hardware present
    If that doesn't work, try a different driver, I've heard win2k drivers work well.
    If it does work, then type in:
    sudo depmod -a
    sudo modprobe ndiswrapper
    now type:
    ifconfig
    and see if wlan is listed. if so:
    sudo ndiswrapper -m
    I also found the Ubuntu Wiki Entry on ndiswrapper
    Now, I just go to system>administration>networking to configure/enable the wireless card.
