Other Why use a 64 bit browser?
Discussion in 'Software' started by Pete J, 7 Jul 2011.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    Hi peeps,
    Just a question that popped into my head and Google searches don't appear to bring up anything particularly enlightening:
    I don't imagine anyone loads up more than 4GB of web pages at a time, right?
  2. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    Tell that to my dad :L he has 4GB of RAM in his machine and it is at a constant 80% load on his RAM.
    that is generally what 64bit browsers are for, for having memory intensive sites open aswell as flash, java api's etc.
    generally you wont need a 64 bit browser if your just doing day to day browsing but if you've got over 30 tabs (like myself) you should probably switch to one.
  3. geoboy333
    28 Sep 2009
    oh and may I say, according to your sig I have to mention, hot damn you must be loaded
  4. Pete J
    28 Sep 2009
    30 Tabs at a time :eeek:
    Not really, just extremely stupid with money :sigh: .
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    30? That's nothing. *looks at Firefox*
    Tab grouping is a wonderful thing...
  6. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Ha, the most I ever get to is 10. Mostly it's just 4 or so.
  7. GeorgeStorm
    16 Dec 2008
    Had 40+ the other day, but in general it's 10-20 methinks.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I use it in an effort to increase 64bit market share in general. Same as many other programs I use that don't *need* to be 64bit. The more 64bit software in use, the more that will be made. I'm looking forward to 32bit being a distant memory much as 16bit is today.
    So really it's why aren't you using a 64bit (insert software)? If it has no disadvantage, there is no excuse.
  9. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Some thing to note:
    32bit applications on 64bit operating systems can address 4GB of memory each (so two 32bit applications can take up 8GB of RAM). Chrome launches a separate application per tab/window.
    The only other theoretical improvement is that 64bit applications can run slightly faster (can do more per CPU instruction execution). This is very unlikely to be humanly noticeable however.
  10. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    I thought it was 2gb per application as on 32bit windows the other 2gb was allocated to the OS?
  11. adam_bagpuss
    24 Apr 2009
    It is in general most 32-bit programs use 2GB of RAM as a limit some use upto 3GB like photoshop but thats about it
    although 32-bit programs can address up to 4GB they very very rarely do
  12. geoboy333
    28 Sep 2009
    When I had XP 32 bit installed on my rig with 4GB it said that it could only access 3.46GB of it. does that limit apply to all 32 bit programs or was it just the OS?
  13. sp4nky
    sp4nky BF3: Aardfrith WoT: McGubbins
    15 Jul 2009
    Win XP hogs about 0.5GB for the OS.
  14. adam_bagpuss
    24 Apr 2009
    Memory limitation dont just include DDR RAM they include all memory attached to the system like video RAM for example
  15. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    See Ask Dan: What's with the 3Gb memory barrier?
  16. geoboy333
    28 Sep 2009
    Just re-counted, got 47 :)
  17. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Last time I tried the ie 64 bit browser, there was no 64bit Flash support, which rendered it more pointless.... than an iPad.
    edit: looks like you can get beta 64bit support for flash now, but I cba to try it out.
