Really think your rig is cool man, but isn't the case a bit of an overkill for the conponents you actually have in it? Whats your plan for cpu/gfx/mobo?
How did you get on with those fans? As quiet as they claim? Mod is seriously impressive BTW, good job! Sam
Im really liking it. It's good to see a practicle, yet, good looking mod instead of something that's just purely sexual and completely useless to use.
I am waiting a little while before any major upgrades....have a 7800gs coming and am swapping the mainboard out this weekend. At some point I will upgrade to either AM2 or possibly Intels' conroe chip but TBH its gonna have to wait a while. I will add another water loop as I've vague plans on a home brew HD cooling...watch this space.
Thanks Sam. The three fans on the rad are real quiet. They are wired into a Zalman fanmate and on the lowest setting they are not audible at all yet provide plenty of cooling. Even at full speed they are still quiet....quieter than the Akasa Ambers I have anyway.
I do like to think of myself as practicle yet good looking Thanks for the continued comments and opinions...they are much valued
really nice case man liking the idea ... although i don't think the res mount looks great, considering the res's are see through ....
is it possible to hold it at the top and bottom, and then by having a block at the bottom you can hide the tubes (make a channel, and have a direct run between the 2 res's) Im not sure how well it would work, but interesting to try maybe ?
The visible tubes at the bottom is my favourite bit! I think if I was going to redo it I would move the mounts further to the top and bottom and maybe make slim metal mounts to blend in with the aluminium caps. Easy to say in hindsight! I may have a fiddle though
I've just finished swapping out the MSI K8T I used for testing and also changed the 6600gt. As it stands the final (for the moment) spec is: Abit KV8 Pro Rev 1.1 AMD 64 3000+ (currently a tad over stock at 2250mhz) 2 gb GSkill PC4000 Club 3D Nvidia 7800GS 1xSeagate 120gb 1xWestern Digital 300gb Hiper 'Type R' 580watt PSU Watercooling is: Alphacool/Ehiem 600 pumpstation Alphacool Nexxos Xp cpu block Alphacool SNB/N NB block Alphacool HC360 rad 2x Cape coolplex 250mm res 3xExtrema Pro 120mm fans on the rad @900rpm 2xAkasa Amber 120mm fans as exhaust @1000rpm Temps are currently: CPU 13c (I'm sure this mainboard reads a bit low ) PWM 29c Sys 25c Both hard drives are at 22c Under full load the CPU temp never goes above 23c and the PWM hovers at 37c. When I had the 6600gt in it had an Innovatec block on and never got above 37c....compared to the stock cooler that ran around 60c Still looking for a waterblock for the 7800GS....anyone seen one? Hope thats enough detail...but feel free to ask for more
doh me being a bozo and watching too many project logs (63 atm) ... Cant really add anything to that, just ignore me
