News WiFi competitor uses visible light
Discussion in 'Article Discussion' started by CardJoe, 8 Oct 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Wouldn't LED fans and the like interfere with these?
  3. Goty
    Goty Minimodder
    13 Dec 2005
    ANY kind of light in the range these LEDs are supposed to operate in will interfere with this system, but I've found an even bigger issue: what if I want to game online with the lights off or surf the internet at night?
    Seriously, why do we pay these people? I want to get paid to come up with impractical solutions to problems that don't exist!
  4. DougEdey
    5 Jul 2005
    They should use IR LEDs or something, but this'll be dead easy to block. Bit o' paint...
  5. Krikkit
    21 Jan 2003
    I suspect that it'll be designed for office work - somewhere where the lights are on all the time.
    The problem with using visible (or even near-visible) light is that it's very easy to interfere with.
    I can see what they're trying for with this one, but I'm a sceptic until further notice tbh. :p
  6. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Only problem I see is that LED lights do not give out enough light. I've tried replacing the halogen bulbs in my bedroom with a set of LED bulbs (they use the same fittings as the halogen bullbs) and they're just not bright enough. I've ended up swithching 1 of the 3 bulbs back to halogen (the one aimed at the computer incidently).
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    No, but I don't want to offer an explanation that could be wrong.
    At the very least, consider that such a system would depend on line of site. There would need to be a sensor oriented up or otherwise towards the light fixture transceiver. Unless you have uber-bright case lighting that is itself an immensely powerful light source, in proxiimity to or aimed at the sensor, everything should be fine.
    Consider television remotes. These work via IR. Many lamps emit IR light as well. Does having a light on in a room prevent you from using an IR remote control with the television? Granted IR remote signals are modulated, but the TV sensor won't/shouldn't pick up non-modulated IR signals even of the same frequency.
    Another thing is that LEDs typically emit at very specific wavelengths, and non-traditional colors emit at very specific color combinations. Maybe that "feature" can help in some way.
  8. liratheal
    20 Nov 2005
    Ah, fair enough. I was asking out of curiosity, since I know jack about light and what has an effect on it.
    That said, I did used to have my PC on my desk, back in the day when it was bright enough to blind the nearest person to it >.>
  9. airchie
    airchie What's a Dremel?
    22 Mar 2005
    This sounds pretty cool but would this not be susceptible to a variant of Van Eck Phreaking? :D
  10. liratheal
    20 Nov 2005
    That is the most insane thing I have ever seen. Evesdropping on monitors?!
    Time to make my monitor a tinfoil hat :D
  11. yuusou
    yuusou Multimodder
    5 Nov 2006
    What if the kiddies wanna watch pr0n and not let their mums know they're up?
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Think they should come with.. warning may produce fits or headaches due to constantly flickering light :duh:
  13. Krikkit
    21 Jan 2003
    At 10Mbps, you won't even get close to seeing it.
    TV remotes don't transfer masses of data though, they transmit a small amount of data loads and loads of times, and even then they can be a bit fussy.
    As for specific wavelengths, yes, LED's emit a very small band of frequencies, but you will still get interference from other light sources, especially white lights.
  14. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Epileptic (sp?) office workers are a thing of the past!
  15. Xir
    Xir Modder
    26 Apr 2006
    Been there, it's called IRDA and used to be standard in mobile phones, laptops etc. ;-)
  16. DougEdey
    5 Jul 2005
    True, but surely we've advanced the IR spectrum refinement now and can increase the data throughput, my phone doesn't have IRDA on it.
  17. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    just improve on current radio signals, rather than go back to line of sight communications like these (even if you say you have lots of led to eliminate line of sight problems), I still find this so called new technology a bit of a let down
  18. Goty
    Goty Minimodder
    13 Dec 2005
    Radio is still line of sight until you get into about 6-meter and greater bands.
  19. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
    Look towards Japan their WiFi networks are crazy.
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    well the nice thing is you could have the wifi where you want it, so like in a room with four walls you dont have to worry about the signal going outside so you could leave it unsecure for guest and not worry about people out side leaching off of it, so ya I can see the applications in this, or like say in Hospitals where such signals interfere with equipment, maybe using the light spectrum wont have the same effect so they would be able to use more wifi based devices.?
Tags: Add Tags
