Networks Wifi security - noWEP, only MAC address limited - SECURE?
Discussion in 'Hardware' started by Phrozenpenguin, 26 Sep 2003.
  1. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Just wondering what peoples views were on wifi security.
    I have mine setup currently using no WEP.
    However i have disallowed all conenctions from network cards, unless there MAC address is on the allowed list.
    Is this secure ?
    Surely there is no way someone can get the MAC address and then emulate it ( i know emulation is possible)
    Or should i crank up WEP encyption as well?
  2. BlackTower
    BlackTower What's a Dremel?
    1 Aug 2003
    You can spoof MAC addresses but of course you would need to know which ones are on the list.
  3. Phrozenpenguin
    11 Dec 2001
    Am i right in thinking that is not easy to get remotely - you cant grab that from packets or something?
  4. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    you can sniff and spoof a mac in 5 mins. not secure at all on its own. even WEP is fairly insecure, have a look at airsnort.
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    As lucifer says, I could come and snoop your network and get all the details I need to hop onto your AP in minutes.
    WEP is your friend, and it's more important than authorised MAC addresses.
  6. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Even though there is a MAC list, couldnt you still see what is being transmitted (without mac spoofing)? Granted it would take special equipment.
  7. Phrozenpenguin
    11 Dec 2001
    OK, thanks.
    So really to be as secure as i can get with my old AP is enable 128bit encryption, and use mac address security.
    And then add passwords to all my pc's on the network....
    What else?
  8. Lucifer
    18 Nov 2001
    wear a tinfoil hat?
  9. Phrozenpenguin
    11 Dec 2001
