Networks WiFi: works fine on PowerBook, no luck on XP laptop
Discussion in 'Hardware' started by ArtificialHero, 27 Nov 2006.
  1. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    Hey all,
    So I've got a wireless connection set up that connects fine when using my Powerbook. The connection is encrypted via WPA. My housemates laptop, running XP (home) connects to the network fine, but cannot access the internet or the internal network. I've tried all the usual suspects, checked the obvious settings, even tried setting up a new user account, with no luck. Any suggestions?
    Thanks in advance,
    Mike
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Has you network got a DHCP Server built in?
    If so check that the computer has the dhcp/router's IP as its default gateway.
  3. ArtificialHero
    25 May 2004
    Hey man, cheers for your post but yeah I'd already configured the default gateway - I should note that I can't connect directly to sites via e.p., not even the routers configuration page.
    AH
  4. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Have you tried temporarily disabling encryption and see if you are able to connect.
  5. kenco_uk
    28 Nov 2003
    Check that there's nothing ticked in the lan settings on the connections tab in Internet Options and that there's no proxy (unless you use a proxy, of course). You mention it connects fine, is it allocated a proper ip address?
  6. seebul
    seebul Minimodder
    9 Aug 2005
    Could be that the XP laptop isnt compatible with WPA, try WEP instead?
