Graphics Will 400W power supply handle 4770? 12v@18a x2
Discussion in 'Hardware' started by lsc04361, 13 Sep 2009.
  1. lsc04361
    lsc04361 What's a Dremel?
    13 Sep 2009
    I know that questions have been asked alike.
    But the answer varies.
    People always saying better to have 26 amps on the 12V rail.
    [The HD4770 draws a maximum of 80 watts. 80 watts / 12 volts = 6.7 Amps. If the rest of your system is typical (a 100-watt CPU, 1HDD, 1ODD, mobo + ram), they will pull another 13 amps or so on the +12V under full load. So look at your PSU's label and see if it can deliver at least 20 Amps on the +12V. If it can, it should work.]
    But what if i got 2 12v rails? 2 and each supply max 18a. Can i took it as 32a?
    CPU: Q6600 95W
    RAM: 2GB
    1 hd and dvd drive
    Motherboard: MSI p45 platinum
    Power supply: SPI ATX 400-PN
    Details:
    OutputVoltage MinimumLoad NormalLoad MaximumLoad
    +3.3V 0.5A 10.0A 28.0A
    +5V 0.3A 7.0A 30.0A
    +12V1 1.0A 7.0A 18.0A
    +12V2 1.0A 8.5A 18.0A
    -12V 0.0A 0.4A 0.5A
    +5Vsb 0.0A 1.25A 2.5A
    *+3.3V and +5V total output not exceed 180W
    *+12V1 and +12V2 total output not exceed 348W
    *+3.3V & +5V & +12V1 & +12V2 total output not exceed 385W
    * Total output for this subject power supply is 400W
    Efficiency: 70% minimum measured at normal AC mains
    voltage and frequency with full load
    Sorry for the rough data presentation.
    Please tell me as i really worried about this.
  2. simonw
    simonw What's a Dremel?
    24 Jun 2009
    It should be fine, as I understand it, a PSU with 2 +12V rails will distribute power to the cpu using one rail, and the other rail will provide power to your other components such as your gpu.
    Generally, I get PSUs with a single +12V rail, just because it is easier to balance out all the power requirements across all components.
  3. Andre_B
    Andre_B Minimodder
    17 May 2009
    Hi
    According to the ATI website, you need a 450w power supply. Link
    Is your Q6600 overclocked at all?
  4. lsc04361
    13 Sep 2009
    No.
    thx.
  5. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    For a customer i did a build.
    Corsair CX400w
    Phenom x4 945
    Radeon 4770
    640gb disk
    1 ODD
    The power supply can easily power this hardware.
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The system in my sig pulls about 350W from the wall (which is only less than 300W from the PSU).
    Any decent 400W unit should be just fine.
