Will a standard 15" screen display a 720p image?
Discussion in 'Tech Support' started by rowin4kicks, 10 Sep 2008.
  1. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    im looking to get hold of 15" 4:3 computer display and hooking it up to my 360
    one question though?
    will it display a 720p image?
  2. GavX
    GavX New Member
    5 Apr 2008
    well they have 1024x768 res so technically that is greater than 720, however 720 is widescreen (16:9(10?) so I don't think you can run HD on that monitor. My mate had his 360 in his 15" but I can't confirm is that was running 720 or 480 (is that the standard?)
  3. wolfticket
    19 Apr 2008
    720p is 16:9, so the horizontal resolution is 1280.
    A 4:3 15 inch monitor has a large enough vertical resolution, but only has a horizontal resolution of 1024.
    So the answer is no, not without downscaling/stretching the picture across one or both of it's axis. Assuming you don't stretch the picture the monitor will probably have to downscale the resolution to around 1024x614 (ish:worried:)
    Any 17 inch monitor would be more suitable (a horizontal resolution of 1280, even in 4:3 form), or maybe even a 15 inch widescreen monitor (they're like hen's teeth, but seem to be around 1280x800)
  4. GavX
    GavX New Member
    5 Apr 2008
    Is this a first hand monitor you are after, or something like an old 15" you are aqquiring? As if you are looking to get a first hand even 22" can be had dirty cheap these days
