Modding will be a project log
Discussion in 'Modding' started by Leevi, 24 Nov 2004.
  1. Leevi
    Leevi What's a Dremel?
    28 Jul 2004
    I'm about to make my own case and I need some help.
    Material for frame.
    Btw. This isn't rust mod.
    Problem is to decide what stuf should I use for it. Frame is iron but I can't make up my mind what to use for sides. Black plexy,alu or wood.
  2. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    Black plexi would look really sleek if you polish up the metal frame.
    Alu would also be nice, as it would look really modern.
    Wood and metal might make it look like a piece of furniture but could work.
    My personal preference would be the black plexi. Very sexy too :baby:
  3. Leevi
    28 Jul 2004
    It' realy hard to polish that 'coz rust has ruined the surfice. I could paint it black thou :idea:
  4. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    If you tke like an angle grinder and grind all the rust off it will show you a nice pretty metal then sand it smooth to what yoou want it to look like then get some sort of clear coat and cover it so it wont rust back up(you have to do this from words of experience i sanded piece down let it sit a month and went and sanded it again because rust came back).
  5. Leevi
    28 Jul 2004
    Well my angle grinder got a bit focked and I had to saw those l-bars by hand :sigh:
