Windows Will Dell do their nut if i remove their software?
Discussion in 'Software' started by Guest-16, 27 Mar 2004.
  1. Guest-16
    Guest-16 Guest
    Got my new lappy here, and its got all this Dell **** on it that i dont want. I wanna just chuck on my WinXP Pro over this crappy Home edn and format everything (they have an AOL icon on the desktop; i nearly cried) and start again? I dont need software support from them, only if the hardware fails which ive got warrenty for anyway. Will Dell tech (depending on whether i can get through to a human) throw a fit and refuse to look at it or can i go ahead and do what i want software wise?
  2. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    short answer: no
    long answer: definately not
    :p
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    dude: its a dell. if it breaks, just slap in that crappy ghost disk they gave you and act stupid.
  4. Guest-16
    Guest-16 Guest
    ah yea! genius :thumb:
  5. Hamish
    25 Nov 2002
    doesnt help if something goes wrong and you cant boot for example
    or the cd drive gets knackered :p
    however, they still wont care :)
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    They surely can't moan if you've done an OS upgrade. If they do, complain to Bill. :naughty:
