A/V Will HDMI on DVD remove issues with PAL/NTSC?
Discussion in 'Hardware' started by mashie, 4 Dec 2006.
  1. mashie
    mashie The one and only
    15 Mar 2002
    Hello, I just want to confirm something.
    I would like to use a UK DVD player in America where none of the local players seems to handle region 2 DVDs thanks to lack of multiregion as well as the PAL image format. So if I get a UK player that upscale to 720p and connect using HDMI to a US plasma screen (that only support NTSC), will it work to play PAL DVDs without having them lose colour?
    Considering the converstion from PAL/NTSC to HDMI rebuilds the signal I would assume this will work. Any thought?
    The 110 to 220v issue is already taken care of btw.
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    all DVD players i have seen with hdmi out supports both formats it seems. (regardless of what output you use.)
  3. mashie
    15 Mar 2002
    Well I know multi region DVD players easily can do both PAL/NTSC, the question is if an NTSC TV can display PAL content if it comes over HDMI.
