Other Will i notice the difference between intel and amd?
Discussion in 'Hardware' started by mushi_999, 29 Nov 2008.
  1. mushi_999
    mushi_999 Minimodder
    24 Dec 2006
    I am planning on getting a second computer from futureshop. Its on sale for 300. I'll just be using it for photoshop,surfing the net and building sites with dreamweaver
    Anyways all my computers have always been intel processor
    But the one i want is a Acer Aspire AMD Athlon LE 1600 2.2GHz Desktop Computer
    Should i stick to intel? will my drivers work with amd?
    thanks!
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Will you notice the difference? Nope! It's like asking if you'll notice the difference between driving a yellow or a blue car...
  3. mushi_999
    24 Dec 2006
    i'd feel cooler with the blue car
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Booting will take longer with an AMD processor, as it uses about 5 secs just to show the post screen.
    I also find the thermal management/protection on AMDs to be a joke. (I have seen coolers melting plastic on AMD based laptops. This was because of dust buildup, though)
    Newer intel CPUs seems to run slightly cooler than similar AMD CPUs. But some of the older intels run ridiculously hot.
    It's not much difference in general, though. It varies greatly between models.
  5. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    As long as there similar CPU, its not a big difference at all, if any. I'm using an AMD and it runs as well as any other processor in its range.
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    not realy unless you sit there with a stopwatch and benchmark all day
