Cooling Will my EK Suprme HF waterblock fit SKT2011?
Discussion in 'Hardware' started by Guest-44432, 18 Dec 2011.
  1. Guest-44432
    Guest-44432 Guest
  2. Guest-16
    Guest-16 Guest
    With ROG X-socket, yes
    :hip:
  3. Guest-44432
    Guest-44432 Guest
    Thanks mate! -I'm going back to Asus (Maximus Extreme) for my main board, so that's good to know.
    Cheers.:thumb:
  4. Guest-16
    Guest-16 Guest
    Rampage IV Extreme and Formula have X socket in the box :thumb:
  5. Guest-44432
    Guest-44432 Guest
    Cheers, Oops, I meant Rampage Extreme. (Maximus was the old naming:duh:)
    Thanks again.:thumb:
  6. Big Elf
    23 Apr 2009
    You'll probably need the new mounting bolts to get the correct tension.
  7. Guest-44432
    Guest-44432 Guest
    I did see this, but those bolts are for the newer HF supreme block. My bolts are threaded right through.
    Anyway, I have now jumped ship to Skt 2011. Order placed, and expected on Tuesday.:clap:
  8. Big Elf
    23 Apr 2009
    It's worth checking with EK. You may need to add 2mm spacers to get the right tension with the stock bolts.
    Edit: You mean the nut's are threaded the whole way through?
  9. Guest-44432
    Guest-44432 Guest
    This is what you are saying.
    I'm saying my bolts are proper screws, threaded from head to tip. So I can screw my bolts into the socket mounts and use a nut to apply pressure on the spring and block.
