Cases Will S'Stone RV02 take GTX 580?
Discussion in 'Hardware' started by neil_b, 15 Dec 2010.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    Per the title, will a GTX 580 (and 570 for that matter) fit inside the latest RV02 (the one with the penetrator fans)? The .PDF for the case on the S'stone web site says it's limited to 10.5" cards, and I can't see a length for the 580 anywhere.
    Thanks.
  2. Edwards
    Edwards Minimodder
    8 Oct 2010
  3. neil_b
    neil_b Minimodder
    20 Jun 2009
    Thanks.
  4. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    The Raven could (just about) fit the 5970, so yes.
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    The 5970 is 11.5 inches long (acually a touch more than that)
  6. neil_b
    neil_b Minimodder
    20 Jun 2009
    So actually it's a NO then, based on Silverstone's own RV02 manual...?
  7. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    No for the 5970, yes to the 580
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
  9. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Yes you are right r3loaded, I was working on the op's comments that it takes up to a 10.5inch card.However Silverstone themselves say a 5970 will fit.
    A pic from silverstone site
