Will the new AMD CPUs work with a Soyo mobo?
Discussion in 'Hardware' started by couzo, 14 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    Seen that the new AMD CPUs will they work with the Soyo dragon Ultra or will they use a different system?
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    yep....well should think so anyway....might need to flash the bios...
  3. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Yep, they should do as they are still Socket A and the chipset is pretty new, but like flix said, you may well have to flash the Bios!
  4. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    if your talking about the hammer series there supposed to be releaseign soon then i dont think they will as they look different to the current type
  5. jamiesurfs
    21 Oct 2001
    Ah yes, the hammer series, I was talking about the latest XP CPUs which should be fine with the Dragon Ultra!
  6. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    were talking about the difference between Palomino and Thoroughbred cores on the XP. Palomino= .18 Thoroughbred =.13. The socket and form factor are the same.
  7. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    AMD made a promise that the new clawhammer will work with Socket A based mobos that supports XP's.
  8. rK@NE
    rK@NE Rover's gonna get it...
    20 Dec 2001
    I believe the ClawHammer uses the socket 754.. and can be seen below
    Note the absence of HSF lugs. Replaced by a similar mounting system to that of the P4... Something IsaacSibson emphatically pointed out a while ago :D
  9. felix the cat
    11 Jan 2002
    i second that it is using a new socket....very nice picture there....where did you find that??
  10. rK@NE
    20 Dec 2001
  11. koos34
    koos34 What's a Dremel?
    6 Jun 2002
    i cant wait till clawhammer. thas gonna be so bada** . im gonna get a dual system:D
  12. Cruelinios
    21 Jan 2002
    mmmm clawhammer, /me dribbles
  13. felix the cat
    11 Jan 2002
    why dual??
  14. rK@NE
    20 Dec 2001
    I can't imagine they will be cheap either...
