Build Advice Will these work together?
Discussion in 'Hardware' started by tizerhead, 23 Oct 2008.
  1. tizerhead
    tizerhead New Member
    1 Dec 2007
    Can you please tell me wether these components will be compatible as a system. I plan to run Windows Vista on this system. Currently, the total prices is £435 and I would'nt like to go much higher. However, if this system can be improved for not much extra cash then please say. TIA Paul
    160GB Western Digital Caviar Blue WD1600AAJS
    7200 RPM
    8MB Cache
    SATA II
    Samsung 22x SpeedPlus SATA DVD-Writer
    Allows high speed 22X writing on a low cost 16X media.
    Inno3D GeForce 9600GT Graphics Card
    512MB GDDR3 / PCI-Express
    500W CoolerMaster eXtreme Power Supply
    20 & 24 Pin Connector
    Asus TA863
    4x External 5.25"
    1x External 3.5"
    6x Internal 3.5"
    Optiarc 20x DVDRWRAM Black
    SATA Interface
    160GB Excelstor SATA II Hard Drive
    160GB / SATA
    7,200rpm
    8mb Buffer
    Mid Range Intel Motherboard Bundle
    CPU: Core 2 Duo E4500 / 2x2.20GHz
    RAM: 2GB DDR2
    MBD: Socket 775 MicroATX
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    That ExcelStor is okay, but it does vibrate a bit. If I were you, I'd ditch the two smaller drives, and go with one WD 640Gb Drive.
    Do you need 2 DVD writers?
    My friend had one of those cases, it's horrible for airflow. He's now happier with his CoolerMaster Elite
  3. Guest-16
    Guest-16 Guest
    The motherboard looks terrible, what's your total budget and what do you really need?
  4. tizerhead
    1 Dec 2007
    Ooops! Didn't realise i'd put in two dvd drives and two hard drives. Only need 1 of each. The hard drive doesn't need to be too big as its only for the OS and software. I have another 500gb one already.
    Total budget is £435
  5. Guest-16
    Guest-16 Guest
  6. tizerhead
    1 Dec 2007
    Just looked at that link...i think that is the best option for me. :)
