Graphics Will this be limiting
Discussion in 'Hardware' started by fdbh96, 22 Mar 2012.
  1. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Sorry to be posting another thread but my gtx 460 has been giving really low frame rates recently compared to my friends' 460. Mine is a 460 SE (less cores) but that souldn't be the difference between Medium and High of BF3 should it?
    Here is what Im on about, it says in CPU-Z that the PCI-E link width is only X1 :eyebrow:
    http://img201.imageshack.us/img201/5784/cpuzpd.png
  2. longweight
    7 May 2011
    Quick links, pictures and albums, upload, right click on the picture, copy image URL, click on the image symbol on the post options, paste image URL.
  3. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    It's almost certainly limiting you, check in power options > advanced and make sure PCIe isn't set to throttle down, and if no luck there, try BIOS options and see if it's been changed
  4. fdbh96
    29 May 2011
    There is one reason why this may be, when installing my cpu, I bent a pin and as a result the top pci-e slot didn't work, so I put it in the lower one, expecting it to run at atleast x8.
    The motherboard is an asus p8p67
