Graphics Will this cut it for Oblivion on high?
Discussion in 'Hardware' started by KayinBlack, 2 Apr 2006.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm looking at upgrading, and as the Sapphire refuses to come out, I'm getting the A8R32-MVP and a 3800+ DC most likely, but as for video cards, would a pair of X1600 XTs be able to handle Oblivion on High (1280x1024) or do I need to look at a more expensive single card? i can actually get into Crossfire cheaper than a single ultra-high end card, so I wondered what was better...
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    I almost always rate the Single better card higher.
    Two main reasons, you can upgrade later, and it'll sell for more later. ;)
    Why not just get a 7900GT? Thats cheaper isn't it?
  3. KayinBlack
    2 Jul 2004
    Then I can't use the multi-card capabilites of SLI on the superior ATi chipset.
    If I get the A8N32 SLI, yeah, but it's not Xpress 3200, which is what I want. The ATi cards score higher in Oblivion anyway.
  4. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    i say go for a pair of x1800gto as now they have crossfire without the cord in back...ill try to find where i read it for you
  5. KayinBlack
    2 Jul 2004
    Well aware of that.
    Still considering it, but I have to do a lot of replacing right now, and my wife just got me a new Ibanez, so I have to be respectful. Or recycle my damaged processor, which really isn't an option.
    Reason this crossed my mind is the fact that oblivion, being held all in GPU memory, might do well with 512 MB x1600 cards in Crossfire. Would love some official word though...
  6. specofdust
    specofdust Banned
    26 Feb 2005
    My advice would be, unless you're buying the very best and want more(I.E 7900GTX's or X1900XTX) then avoid dual card solutions. They invariably give less performance per dollar then you'd get if you just piled all that money into a single, higher end card.
  7. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    I only have a 7800gs and Oblivion runs great. I would just go with a good single card for now and then use that add in card upgrade later.
  8. hobbs
    24 Jun 2005
    what happened to your cpu?
  9. KayinBlack
    2 Jul 2004
    Lightning damage. Blew my APC surge suppressor and all.
  10. ToiletGamer
    ToiletGamer What's a Dremel?
    29 Mar 2006
    X1800 XL or above I would say.
  11. KayinBlack
    2 Jul 2004
    Got an X1900XTX on a deal, so I'm all taken care of.
    Wife wants to play Oblivion too.
    Son of a monkey came busted. This is not cool.
