Modding Will this LCD show through?
Discussion in 'Modding' started by error.ini, 7 Oct 2003.
  1. error.ini
    error.ini What's a Dremel?
    25 Aug 2003
    I plan on putting some pre-tinted plexi over my drive bays, and in bottom 2 put one of these 2 LCDs in it. Do you think they will be bright enough to show through tinted Plexi when they're on? I think stealthed LCDs look so bad ass, and these would match my case scheme perfectly.
  2. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    really depends on how 'tinted' the plexi is?? them displays look bright, hold a dull led up behind the plexi and have a look how much light you can see.
  3. error.ini
    25 Aug 2003
    Ah good idea! I'll do that when I order the plexi. Now I think it will work, because right now i have some like %20 tint, and dull leds show through ok.
  4. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    MMMM, they should, smoked plexi tends to transmit more red light than any others, however they look pretty dim. If a normal brightness red led doesent show, I would suggest tring to get an VFD with a red filter.
  5. error.ini
    25 Aug 2003
    Do you happen to know of a site with cheap prices that ships in the US? *(for VFD)
