Education Will this Replace my Dremel?
Discussion in 'General' started by TheGreatSatan, 18 Sep 2012.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Will this be able to replace my dremel?
  2. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    I certainly wouldn't say no t having it added to my tools. It wont replace a dremel but it'll be damn useful for a slot of stuff.
  3. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I really want that ! it'd probably get more use than my dremel.
  4. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    That's pretty dang handy, and it's safer to use because you know why? It's easy to control and no jumping around with jigsaw, dremel, etc.
  5. wolfticket
    19 Apr 2008
  6. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Yep- there are quite a few different brands with this type of tool available.
    It does look useful for cutting straight lines in 'soft' materials, though I wonder how well they cope with something like a decent thickness of aluminium for example..
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    You would lose all the drill like bits that are available for the dremel (engraving/buffing bits etc). A dremel would provide a more useful range of tools imo.
  8. Cheapskate
    13 May 2007
    These are good for cutting in awkward places mostly. Fein is a particularly expensive brand to chose for one. If you want to spend buttloade 'O cash for a rotary tool replacement, I'd go with a Foredom.
  9. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice looking tool but I would agree with the others I don't think it will replace the dremel. But wold defiantly be a nice to have.
  10. TheGreatSatan
    5 Aug 2005
    I wonder if it would cut a side panel window faster.
  11. Gaming_freak_10
    5 Jun 2010
    I think you might have to try it and report back??
