Windows Will this simple setup host HL2DM and CS:S servers?
Discussion in 'Gaming' started by khjb007, 18 Feb 2006.
  1. khjb007
    khjb007 What's a Dremel?
    18 Feb 2006
    AMD Barton 3000
    Memory: 1024MB
    Primary Storage: 80GB SATA Hard Drive
    Operating System: Windows Web Edition
    Monthly Bandwidth: 1000GB
    Uplink Port Speed: 100Mbps
    I'm planning on running 20 slot HL2DM server and
    20 slot CS:S. After reading many articles, I've come to a
    conclusion that with this setup, it would be fine to run
    two servers without significant lag. I need opinions from
    everyone who has had any experience with running multiple
    servers. Thank you for the help in advance.
  2. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    The only thing you'd need to watch out for is memory usage. Other than that, the setup should work fine.
    You should also look into increasing the tickrate of the servers; provides a smoother experience when yer playing, but it can hog CPU time. If you're only planning on running 2 servers on that hardware though, you should be fine.
  3. khjb007
    18 Feb 2006
    thank you very much for the reply!
