Electronics Will this VU meter curcuit work?
Discussion in 'Modding' started by dreamie, 24 Nov 2002.
  1. linear
    linear Minimodder
    5 Oct 2001
    It looks pretty much okay at first glance, but the resistor in the power line is unnecessary. 12V supply is fine.
    Your power switch is drawn a little oddly, but the overall idea of switching the supply is okay.
  2. linear
    linear Minimodder
    5 Oct 2001
    Jeez, you don't even give me time to look it over carefully.
  3. dreamie
    dreamie What's a Dremel?
    6 Aug 2002
    u mean i should not use any resistor b4 the LEDs? :eeek:
    ( electronics n00b here :blush: )
  4. linear
    linear Minimodder
    5 Oct 2001
    You have the resistor in line with the voltage supply to the IC as well.
    The driver IC already limits current to the LEDs, so yeah, yank that resistor out.
    See, it just keeps getting simpler. Did you read the datasheet at all?
  5. dreamie
    6 Aug 2002
    i dun understand datasheets :blush: :blush:
    so i just need to yank the 680ohm resistor @ the bottom out? which means there's only a resistor to limit the current for the pwr led?
  6. linear
    linear Minimodder
    5 Oct 2001
    yeah.
  7. dreamie
    6 Aug 2002
    thanks.. but if my LEDs blow... (I'm gonna use 60 LEDs, 30 per channel)....
    I'M GONNA CRY!!!
  8. linear
    linear Minimodder
    5 Oct 2001
    They won't, that's one of the nice features of that IC, it is a current-limited LED driver. *And* if youwant to limit the current even more, there's a pin for that purpose. Don't do it the way you drew.
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You can't use that many LEDs. The current limiting set by the two external resistors (the same two resistors that control the voltage at which each output will light up) on the chip will only allow enough for one LED per output (possibly two).
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Put them in series ;)
    Just watch the total power on at once, dot mode will run more leds than bar mode.
  11. dreamie
    6 Aug 2002
    here's a new diagram:
    Can you see it? :D
    Comments?? :D
  12. dreamie
    6 Aug 2002
    no one? :sigh: :sigh:
  13. dreamie
    6 Aug 2002
    did a search on the net (google :rock: ) and found some curcuits:
    I find the first one good, but I need to add in a VR somewhere so that I can control the sensitivity of the curcuit. Could someone comment on these and mine? I wanna try my curcuit but i'm afriad it might not work.
  14. linear
    linear Minimodder
    5 Oct 2001
    They're all right off page 2 of the datasheet, with minor modifications in each case. They should all function. Including your latest.
  15. dreamie
    6 Aug 2002
    Thanks, but should I connect the LEDs in // or series?? :)
    TIA :D
  16. linear
    linear Minimodder
    5 Oct 2001
    Series it is.
  17. dreamie
    6 Aug 2002
    Thanks. Having a hard time soldering these colse joints. Just received my samples from National yesterday and was soldering them yesterday. The joints were really close and I havent strained my eyes these much since unlocking my Athlon XP. :blah:
    Now i'll have a easy time solder those in series! :D
  18. dreamie
    6 Aug 2002
    Just completed my soldering and stuffs for this VU meter and i'm stunned.... cos it's working... :p
    gonna get a stereo audio splitter now so that I can use it wif my speakers. :D
  19. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    awesome, put some piccies up :D
  20. dreamie
    6 Aug 2002
    i dun have a digicam :sigh:
    but i'm currently browsing thru some DC brochures! :D :hip:
