Networks Will this work?
Discussion in 'Hardware' started by xen0morph, 23 Dec 2002.
  1. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Ok, I'm setting up a Celeron/400 with 64 megs of RAM, 2 gig of HDD space and onboard everything as a server. (Only thing I'm putting in the case is the mobo, a PSU and the hard drives :D ) I'm gonna run Win2k Pro on it, set it up with ICS on my Voyager ADSL modem, and also use it for http.
    Will this work? Would I be better off with 2k Server?
    :D
  2. RTT
    RTT #parp
    12 Mar 2001
    Yep it'll work fine :)
  3. xen0morph
    30 Jun 2002
    Thing is I'm using it to share the connection between XP boxes, will there be any problems with XP machines sharing the connection on the 2k box?
  4. herbs
    herbs Nobody but us chickens
    7 May 2001
    I think you will be better of using it as a smoothwall box. www.smoothwall.org or the latest ipcop beta that support internal pci adsl cards and external usb adsl modems.
  5. RTT
    RTT #parp
    12 Mar 2001
    but then he wont be able to use it as a webserver?
  6. herbs
    7 May 2001
    True didn't read that bit (again!!!)
  7. RTT
    RTT #parp
    12 Mar 2001
    Not at all, the XP/2k networking is virtually identical and works together brilliantly :)
  8. NetGuy
    NetGuy What's a Dremel?
    23 Dec 2002
    RTT is correct, I've tried using the ICS on everything from 98SE to XP, and it's always worked. Doesn't work quite as well as a hardware router (obviously), but if you're on a budget it's all good.
