Electronics Will this work?
Discussion in 'Modding' started by talladega, 9 Jan 2012.
  1. talladega
    talladega I'm Squidward
    18 Aug 2007
    So over the next month or two I will be building a mini-itx file/media server. I want to have it place right by the modem and router and switch. I was thinking that I really dont like having so many power cables, so why not have the modem, router and switch get power from the server's PSU?
    This is the switch http://www.newegg.com/Product/Product.aspx?Item=N82E16833156251
    This is the router http://www.newegg.com/Product/Product.aspx?Item=N82E16833320038
    The switch uses 5V @ 1A
    The router uses 12V @ 1.25A
    The modem is about the same as the router.
    So, would it work to take the 12V line and mount a power output via something like this http://www.allelectronics.com/make-a-store/item/DCJ-25/2.5MM-DC-JACK-PANEL-MOUNT/1.html
    I could do 1 each for the router and modem and then do a 5V one for the switch.
    The result would be my server being plugged into a UPS and then my router, modem and switch being plugged into the server, eliminating the use of 3 outlets on the UPS/ surge protector.
    So, will this work?
    If yes, any suggestions/tips on the best way to do it?
    If no, why??
  2. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    It will work but you will need to drill holes either on the case or a blank PCI bracket. Furthermore, you need to be careful as to which connector you're using because they will both carry different voltages.
    Why not use this instead:
    http://www.amazon.com/PCI-Power-Panel-Pin-connectors/dp/B003L16ZOK/ref=pd_cp_e_3
    It's a PCI bracket with 3 Molex connector passthroughs.
    The cable you need to make is simply like this:
    Since each molex connector carries both 12v and 5v in addition to ground and has a specific pin-out, you can safely connect to any of the 3 molex connectors without risk of applying the wrong voltage to the devices.
    On the up side, you get up to 2 more molex connectors if you want to simply connect a regular computer case fan for use outside of the system. Useful to make a cheap desk fan with spare case fans lying around. :)
    talladega likes this.
  3. talladega
    18 Aug 2007
    Awesome. Thanks for your input! :thumb:
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Most routers and switches I encountered were using 9 V.
    I would dissasemble switch and router power adaptors and solder AC from power supply to them.
  5. inzane86
    inzane86 engineer with an axe
    15 Jan 2004
    It will work, and I think it's a great idea.
    Depends, how neat you want to make it, you could just cut of the leads from the switch and modem powerbricks and connect them to a male molex plug.
