Build Advice Will windows7 upgrade serial key work on Win7 full?
Discussion in 'Hardware' started by Siwini, 14 Jan 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Hi, I have Windows7 Professional full installed on my PC. I just finished another build and I was wandering if I can buy another Windows7, but upgraded version because I already own full 7 and it's $100 cheaper. Can I use serial key from upgraded version to install a full version?
  2. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    Yes, though to satisfy the license you should technically have another version of windows that you're not using (eg, an old XP license), but there's no need to install an OS before upgrading.
  3. Siwini
    14 Sep 2010
    It's a clean build so needs full installation. So yah if I can buy windows 7 upgrade and use it serial key. Pretty much all I need is a cheap serial key because I already got windows 7 professional full. To my understanding you can use one key per system.
  4. adam_bagpuss
    24 Apr 2009
    yes you can and it is 1 key per system unless you own a VLK which im guessing you dont as it really a business thing.
  5. asteldian
    asteldian Minimodder
    13 Jan 2011
    Yes you can, though what you own is irrelevant - if you buy the Windows 7 proffessional upgrade, the disks are identical to your full version, the only reason for the price difference is the licensing. So, with your new copy you can install Win 7 on the new machine but you want to avoid activating with the code as it won't recognise it as it was an upgrade key installed on a clean HDD. So, once installed you either need to reinstall it again and then put in the key or you can go into regedit and adjust things there to allow the code to work. I cannot remember the full details as it has been awhile since I did it. But basically if you go to google and type 'installing Windows 7 on clean hard drive' you should get step by step instructions
  6. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    If its a new build you qualify for the OEM version. Surely cheaper again.
