Windows Win 10 Creators update iso puzzle.
Discussion in 'Software' started by Kronos, 24 Dec 2017.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am going to do a fresh install of Windows 10 shortly and I have created a USB ready for that purpose. I thought that while I was at it I could add the Creators update iso to the same USB so that i can install directly after Windows to.
    But here is the dilemma the USB is 16Gb after sticking Win 10 on it I am told I have 11Gb, the creators update it says is just over 4Gb yet I am told it is too big for the destination drive.
    What am I missing?
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    IIRC there's a bug with Windows where it get's confused with USB drives formatted in FAT32 and space remaining versus actual space and actual file sizes, have you tried copying another largish file like a 1GB-500Mb movie to it temporarily so it changes the available space and doesn't confuse Windows.
    Either that or you're hitting the 4GB size limit for single files on FAT32, if so you'll probably need to reformat the drive as either exFAT of NTFS.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have found another 16Gb USB and using Rufus have managed to mount the ISO which will do. Thanks mate.
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Erm. Why don’t you just use the Windows 10 Media Creation Tool to download an iso? It’ll automatically be the very newest Creators Edition Fall Update version and you can use Rufus to burn that to a USB.
    Then you can install latest version direct with far less hassle?
    I know this works, I’ve done it with at least the last five versions of W10.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    windows tool will make bootable usb for you, you don't need anything else to do it?
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    I moved this to the Windows 10 thread and have already done what you suggested, thanks.
