A/V Win 10 updates stops my sound working
Discussion in 'Tech Support' started by Mr Happy, 15 May 2019.
  1. Mr Happy
    Mr Happy 4 8 15 16 23 42
    25 Apr 2009
    Hello all
    Since moving to Win 10 a while ago, my sound has suffered on every single Win 10 update.
    After each update I will boot my PC and I can guarantee that my sound will have stopped working, and the only way this can be fixed is by uninstalling the software followed by a fresh install
    I have tried to look into this but I have not got anywhere! So my hopes lie with the skilled folk on this forum.
    I am currently running WIn 10 64 bit, and my Soundcard is a Soundblaster Z
    Has anyone else come across this or knows of a fix.
    Maybe there are better soundcard options out there for me to look at?
  2. RedFlames
    23 Apr 2009
    IIRC it is or was a known issue with Creative cards... one Creative appear not to have bothered fixing [or at least they do;t appear to have for the Z]...
    Mr Happy likes this.
  3. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    If you're running your monitor on HDMI, check your default sound output - it may have been set to HDMI and if your monitor has no speakers, you won't hear any sound until you switch back to your SB output.
    Any other monitor hook-up or HDMI into monitor w/speakers & I'm outta ideas.
    EDIT:
    I'd go w/ @RedFlames thinking...
    EDIT 2:
    Compare this to what you have, already
  4. Mr Happy
    25 Apr 2009
    Thank you for the reply's. I am starting to believe it could be a creative problem. The soundcard works fine, until the point of any given update. To be honest, I bought this card as an upgrade from my XF-I Fatal1ty gamer card, but it does not sound as good IMO.
    I may look for another card to replace this one
  5. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
  6. Big Elf
    23 Apr 2009
    You could disable automatic driver updates. It does mean you'd have to check your other drivers for updates manually though.
  7. Mr Happy
    25 Apr 2009
    Thanks. I have installed the drivers on a different HDD from the OS. Will see if it works
