Windows win 2000 pro
Discussion in 'Software' started by CatKing, 18 May 2003.
  1. CatKing
    CatKing What's a Dremel?
    10 Nov 2002
    hi all,
    can somebody show me a free program to disable start up program in win 2000 pro?
    thanks
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    What do you mean startup program ?
    If you want to disable/enable proggies that startup then just click start menu -> run and type msconfig and press enter.
  3. CatKing
    10 Nov 2002
    hi,
    thanks for the reply.
    it cant do it in win 2000 pro. anyway just go it by searching the post.
  4. nigga_supreme2003
    nigga_supreme2003 Banned
    29 May 2003
    You could try using a program like sysyem mechanic for 3rd party program's like that you installed yourself & (or) control panel> administrative tools> services - for component's that come installed with window's 2000. Hope that help's you!!
  5. mrmagoo_83
    mrmagoo_83 What's a Dremel?
    4 Dec 2002
    google for WinXP msconfig.
    It works for win2k also.
  6. CatKing
    10 Nov 2002
    thanks
  7. chapman34
    chapman34 Banned
    25 May 2003
