Windows Win 7 N edition ISO download
Discussion in 'Software' started by CrapBag, 13 May 2013.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have been given a genuine activation code for Win 7 N edition but I can't find anywhere to download it.
    Can I use a normal Win 7 iso, is it like older version of windows, the disc contains all versions but the activation key determines what will be installed?
  2. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Although i'm not fully sure, given that its windows 7 minus a few features, i'd say the normal iso will work.
  3. jinq-sea
    15 Oct 2012
    AFAIK (it's a while since I've dealt with this) all Win7 ISOs are basically identical. It's got to be worth a lash?
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    if you have access to a copy of windows 7 any version, copy to a folder on your pc, remove the ei.cfg file, and burn a new disk, it will then install the version related to the license key you have
  5. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    If the above tips don't work:
    Windows 7 N Version Direct Download Links [Windows 7 N English for Europe - No Windows Media Player (WMP12)]
    Windows 7 Home Premium N x86 (32-bit): http://msft-dnl.digitalrivercontent.net/msvista/pub/X16-13457/X16-13457.iso
    Windows 7 Home Premium N x64 (64-bit): http://msft-dnl.digitalrivercontent.net/msvista/pub/X16-13459/X16-13459.iso
    Windows 7 Professional N x86 (32-bit): http://msft-dnl.digitalrivercontent.net/msvista/pub/X16-13548/X16-13548.iso
    Windows 7 Professional N x64 (64-bit): http://msft-dnl.digitalrivercontent.net/msvista/pub/X16-13550/X16-13550.iso
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Cheers for the help guys, I'm installing now on an old rig using the standard 64bit home premium ISO I downloaded from MS so we will see if it works. It's to be used on a friends build at a later date which is why I'm testing it on an old rig.
    If it doesn't like the key then I'm already downloading the 64bit N ISO that Lancer linked me to.
  7. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Standard ISO doesn't work so hopefully the N ISO will once I've downloaded.
  8. wolfticket
    19 Apr 2008
    This apparently doesn't work for switching between N and standard versions.
    Seems silly to me, but good to know.
    There didn't seem to be any obviously available information as to whether N and standard versions were compatible when it comes to ISOs and licences. I guess not.
    Hope the downloaded ISO works fine.
  9. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    N ISO was fine with the product key but it wouldn't activate, nor will it update for some odd reason.
  10. wolfticket
    19 Apr 2008
    Try activating over the phone. Generally works if you have a valid key that won't activate for whatever niggly reason.
  11. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    /Edit wrong thread,
    I'm clearly a noob
  12. RichCreedy
    24 Apr 2009
    having never even touched n versions of windows I didn't realise, good to know, but am unlikely to use
