Windows win xp problem
Discussion in 'Software' started by nissansilvia, 31 May 2004.
  1. nissansilvia
    nissansilvia What's a Dremel?
    31 May 2004
    everytime i try to access something through the run command or like a windows screen for example msconfig .... it appears for a sec and then dissappears idk wat the problem is. can someone help?
  2. Sniper-X
    Sniper-X What's a Dremel?
    27 Mar 2004
    sounds like a error is popping up when you use the run command it opens a virtual dos box (because xp doesnt have real dos like win 9X) and if it encounters a error it will go ahead and close down the dos box ...try to opening up a dos prompt and entering the command that way the box will stay open and you can see what the error is ....good luck
  3. nissansilvia
    31 May 2004
    i will try that thanx. any other suggestions people? thanks
