Windows Win7 problems
Discussion in 'Software' started by Ozzie, 11 Oct 2013.
  1. Ozzie
    Ozzie Fork 'andles I wanted
    14 Sep 2013
    Hi all, I am having endless problems with win7 that was working OK a few days ago. Firstly is became so slow that it was ridiculous but still worked. Now it will boot but sometimes stops at the welcome screen saying please wait.
    If I do get to the win7 screen nothing will work when I click on it just the blue circle appears going round but never gets anywhere, sometimes if I move the cursor to the start orb then that is the end nothing happens and can't even move it anymore..
    I have tried everything I can think of, system restore which failed a few times but I managed to get it back to an early time which still did not work nor can I undo it now, I can get into safe mode, tried last known good fig but no joy, tried reseating the mem cards. When I could get to task manager CPU was showing 100% all the time but that may be misleading.
    I have a Paragon backup on external HDD but can't access it.
    I am using the same PC now to post this but using XP on another drive, can anyone help please as I can't think of anything else other than factory restore which I really don't wan't to have to do.
  2. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Honestly I would save anything I could of importance and wipe the computer. It sounds like malware or a virus. But it is the only defiantly way to fix the problem since it seems to be a software issue
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    What process is using %100 of the CPU ?
  4. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Have you tried booting it into safe mode without networking and trying something like a system restore or a virus check to see if a virus is making trouble?
  5. Ozzie
    14 Sep 2013
    Tried everything that I can think of including trying to clone it from a backup drive but no joy.
    It now won't boot at all NTLDR missing. I do have all important stuff backed up on 2 different drives, just did not wan't all the bother of a clean instal. HDD failure is the only thing I can think of unless anyone has any more ideas. Thanks for suggestions.
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Only other thing I can think of really is catastrophic Windows update failure. I would run the hdd manufactures diagnostic utility. If the disk checks as good reinstall win7.
  7. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    My bet is a failing hard disk.
    Have a look at the smart info.
  8. Ozzie
    14 Sep 2013
    It was updating or not updating all the time, saying it was updating then stopping so I could only do a cold boot, this went on for hours.
  9. Ozzie
    14 Sep 2013
    That was what I was thinking but some other points have now been raised. I don't want to scrap a fairly new drive about 18mnths old if the problem is something else. Thanks for your response.
  10. RedFlames
    23 Apr 2009
    I'd do the following:
    Visrus/malware scan
    Check HDD
    run - sfc /scannow [in command prompt, as administrator]
    if that fails [says it found problems and fixed them says it can't be repaired], or even if it doesn't run
    run - dism /online /cleanup-image /restorehealth [again elevated command prompt]
    if all else fails - bin it [the win7 install] and start over...
    EDIT: both of those commands [with slightly different options] can also be done from the windows disk, but I can't remember off the top of my head what the commands are...
  11. Ozzie
    14 Sep 2013
    Hi again, been having another go at it but no luck. I can't get past the NTLDR message
    booting from HDD. Can boot from the CD to Recovery Options OK.
    Startup repair says it cannot automatically repair. System restore gives error messages
    (0x80070067) or (0x80070002).
    Also ran chkdsk but it failed to save the log. New cable just in case.
    I can start up fine on the same PC using the other XP drive and I can see and read files
    on the Win7 disk.
    If I start new install from the CD will I get the Repair option as I do with XP ie
    it starts as if doing install but you have the option of pressing R to repair without
    losing all your programs.
  12. Ozzie
    14 Sep 2013
    I was wondering if I could repair the boot files from within XP somehow.
  13. RedFlames
    23 Apr 2009
    from the windows 7 USB/CD you should be able to open a command prompt
    try
    Code:
    sfc /scannow /offbootdir=x:\ /offwindir=x:\windows
    where 'x' is the drive 7 is on [it may vary what your drive is picked up as]
  14. Ozzie
    14 Sep 2013
    Thanks to all for trying to help but I give up now and will go for the new install as nothing else seems to work.
  15. RedFlames
    23 Apr 2009
    Indeed there comes a point where it's not worth trying to fix...
  16. Ozzie
    14 Sep 2013
    Posted 4 minutes ago at 10:50PM
    This is getting beyond my comprehension now. I tried to do a clean install from the DVD and got 2 options Upgrade or Custom, warning says custom will lose all your data so I tried update. It told me to remove the disk and start windows normally in order to proceed. I tried that thinking no way I could do it, then it brought up Win7 which I am using now to post this. Got it back and running but don't know what to do next. I don't want to shut it down in case it never works again totally confused now.
  17. RedFlames
    23 Apr 2009
    while it's up and running try what i posted above [sfc then dism]
  18. Ozzie
    14 Sep 2013
    I have finally managed to recover this from an external backup drive which did not want to co-operate earlier. Thanks to all for your help and advice. Oz
