Windows Win8.1 can I forcibly turn off a usb-harddrive?
Discussion in 'Software' started by Xir, 23 Jan 2015.
  1. Xir
    Xir Modder
    26 Apr 2006
    Hi,
    I'v got a hybrid Laptop/Tablet. (Convertible?)
    It looks like a laptop, but really is a tablet with a base.
    The base consists of a laptop-hinge, a keyboard, a second battery and a harddrive.
    The system runs Win 8.1 64bit
    This harddrive in the base is detected as an external USB-Harddrive, and it's the only moving mechanical part in the system.
    I'm usually not using it (it's only a data storage) but it runs all the time.
    Is there a way to shut it down and restart it on demand? Like an installable on-off switch?
    Best regards,
    Xir
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    You could give HDDScan a go, it's a bit clunky and is far from an ideal solution but i can't think of anything else.
  3. Shirty
    18 Apr 1982
    I suspect you'll only be able to do it by disabling the port in the BIOS.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Disable it in Device Manager?
  5. David
    7 Apr 2009
    Replace it with an SSD?
  6. Shirty
    18 Apr 1982
    That would be the best course of action if it's possible.
  7. wolfticket
    19 Apr 2008
    While forcibly doing anything, if it's not on already turning on "USB selective suspend" on the power plan (in advanced power settings) may help.
  8. Xir
    Xir Modder
    26 Apr 2006
    It's the data drive, replacing it with a 500GB SSD would almost cost me more than half of what the entire system cost :D
    I'll try, I think it's also indexing, or thumbnailing or whatever the heck Win8.1 thinks is neccesary doing ALL THE TIME. :grr:
