Windows Win8 pro upgrade- ended up with dual boot?
Discussion in 'Software' started by cdb, 29 Jan 2013.
  1. cdb
    cdb No comment
    25 Apr 2009
    I upgraded Vista 32bit to Win8 64bit today and it gives me the option to load Win8 or Vista?!?
    I booted from a dvd (image saved to it from the download) so I assume it was a clean install.
    How can I get rid of the vista option? Another reinstall.
  2. wolfticket
    19 Apr 2008
    I saw the Windows 8/7 dual boot screen once when Windows 8 first booted. It was a clean install onto a partition with W7 already installed (without formatting). I then never saw it again on any subsequent start ups.
    If it's doing it persistently but there is no W7 install actually on the system then it's probably just the bootloader. The repair option on the OS select screen should help I imagine.
  3. Addie
    Addie Member
    9 Jan 2009
    The reason you have ended up with a dual boot machine is because you cannot upgrade from a 32bit OS to a 64bit OS, it needs to be a clean install. It is probably easiest to just do a clean install now, I expect it is using the vista boot loader, so unless you want to fiddle with changing that a clean install will be simpler.
  4. cdb
    cdb No comment
    25 Apr 2009
    I thought I had done a clean install booting from the DVD. What did I do wrong then?
  5. fdbh96
    fdbh96 New Member
    29 May 2011
    You have to do a custom install, its one of the first screens when booting from the disk. After selecting custom, the drive you want to install win8 on should be formatted.
  6. cdb
    cdb No comment
    25 Apr 2009
    Sorted, but having trouble with updates failing and 4 yellow exclamation marks that need sorting.
  7. cdb
    cdb No comment
    25 Apr 2009
    Well I got rid of 2 of the exclamation marks.
    Giving up on the windows updates as they keep failing. Got it down to the last 5 now. Only taken somewhat over 3 hours. Can't say Win8 is impressing me so far.
  8. cdb
    cdb No comment
    25 Apr 2009
    Well after failing updates, device drivers not loading, bluetooth not working, one blue screen, various system hangs, Win8 pro can go hang itself and the wife can carry on with Vista.
    Spent about 4 days trying to sort this. Installed Win7 pro and had no issues in a couple of hours.
  9. fdbh96
    fdbh96 New Member
    29 May 2011
    At least you can sell your license for loads now :)
  10. cdb
    cdb No comment
    25 Apr 2009
    Yeah, true. I noticed when I moved my hard drive into a newer laptop to try and get round the update issue (which worked btw) it said this copy of windows was already activated on another pc. How do I unactivate it so I can sell it or more likely use it legit on another pc?
  11. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    phone actiivation
