We talking the Remote control software? Not sure about Girder, but I've found IRAssistant to be easier to configure. If not, then: <EdiT> Miriam comes complete with controls for loads of programs, including winamp, power dvd, bsplayer, wmp, etc etc.
starting to learn this stuff now... but i just ran into another problem... if i want girder to write something... then press enter (using it for mirc)... how do i get the enter key? another tihing: if i want it to change my MSN staus.. i can just hold in alt and press f-m-a (file-my status-away) but how do i get girder to hold in the alt key all the time? (if it presses alt for each time it will go mad.. ) anyone?
ok... i figured out that too last night... i get it to open the file menu... but it won't go any further.. no matter what... what i have done is making an command that presses the alt key and writes the sentence "fma" when a button is pressed.. i have also tried each letter in each command (same input)... still won't work... anything else i can try? also.. haven't got any further on the enter thing...
Try that, putting a half second pause between each keystroke to do your MSN: Alt -> Pause -> F -> Pause -> M -> Pause -> A Let us know if you have any luck.
wohoo! thanks for the help! i figured out that i didn't need the pauses.. i just had to tick off the "alternative proc.".... i have no idea on what it means but.. ohwell.. the only thing that is wrong now is that i have to make girder restore MSN before it can change my status...
