Windows winamp playlist creator
Discussion in 'Software' started by theagent, 28 Jun 2004.
  1. theagent
    theagent What's a Dremel?
    4 Nov 2003
    does anyone know of a program [most likely very small] that you could use to make winamp playlists for you? i just reformatted and i have 190 albums sitting on my d: without playlists, and i dont really feel like making them... again :)
    just wondering if there's a program that will look at either the ID3 tags or the folder name and make playlists for you
    also, is there a way to add a 'sort by track' feature to winamp? unless i just cant find it, v5 took it out, and having that makes creating playlists much faster. maybe a plugin or something?
    thanks
    the_agent
  2. theagent
    4 Nov 2003
  3. m4rk3d
    m4rk3d Minimodder
    15 May 2004
    Dunno if it's any use, haven't tried it meself, but a quick google search turned up:
    This
    And a wander on the Winamp plugin site chucked this one my way:
    plugin
