Windows Winamp + vista64 = stuttering
Discussion in 'Software' started by kingred, 20 Dec 2008.
  1. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Hello,
    I am experiencing stuttering on a loaded cpu, i am running vista enterprise 64. I recently changed reformatted and now i am experiencing this issue, its only come up on this install, so can anyone share any advice on how i would stop it as it is very annoying.
    Cheers.
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You don't have a Creative sound card, right?
  3. Krikkit
    21 Jan 2003
    I've had this issue before, and the only way I've found is to reformat tbh. :(
  4. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    is it only in winamp?
  5. kingred
    27 Mar 2008
    yup only in winamp. time to look for viable alternatives which can handle my library :(
    no i am using my motherboards standard onboard jazz which made me buy the mobo in the first place so i dont have to resort to using my firewire interface. could it be a latency issue?
    is foobar any good?
  6. kingred
    27 Mar 2008
    Ok, i might have fixed it, i played about with the settings on the actual card and its cut it down, however it seems only affected when firefox's bloat impinges on it, as at the moment minefield/shiretoko/firefox 3.1 beta 2 loves to memory leak.
    why do they mess up decent beta's of firefox with utter crap? shiretoko was excellent, fast, didnt require 4gb+ ram. how stupid is that :/
