Windows winblowsXP problem
Discussion in 'Software' started by malMethod, 11 Jul 2003.
  1. malMethod
    malMethod What's a Dremel?
    9 Jul 2003
    hey everyone, i just registered, but i thought i would post my problems that im having with my computer.
    yesterday, out of nowhere, my system restarted itself. it gave a blue screen with a whole screen full of stuff, which went away quickly before i could read anything, then proceded to restart. the only thing i could catch was near the bottom which said "physical memory dump........" since then it has done this 3 more times in windows, and now, it will does this right away, right after it checks the hard drives etc in the boot process, not even letting me into windows.
    my brother said it had something to do with my T-Bird 1ghz chip. he said on some of them, they were faulty or something i dunno. anyway, i cant just reinstall windows either because i dont have a cd or disks. so am i SOL now? :duh:
  2. ajack
    ajack rox
    17 Apr 2003
    I had a similar problem a bit ago. firstly, in order to read all of what the BSoD says, right click my computer>properties>advanced tab>startup and recovery - settings>uncheck automatically restart.
    Reasons for this BSoD are different, for me it was my hdd that was foobared. I suggest you download a memory tester and hard disk diagnostics to check them. Replace any other hardware you can get your hands on to try and determine the problem.
    Welcome to the forums btw :D
    JW
  3. malMethod
    9 Jul 2003
    first of all, thanks for the welcome!
    however, i cant even get into windows, so i cant do any of what you recommended.:yawn: :(
  4. Ubermich
    Ubermich He did it!
    21 Jun 2002
    you can do the memory tester IIRC it's done before getting into windows...
  5. ajack
    ajack rox
    17 Apr 2003
    yah memtest86 is used on a boot floppy disk so ya can do that
  6. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Also might want to make sure everything's plugged in good. Could end up being something as simple as an IDE cable that's becoming unplugged...
  7. malMethod
    9 Jul 2003
    well i made sure everything is plugged in securely, but where can i get a memory checker or whatever? and are yall saying i can run it without windows? sorry for the noobie questions, im just a graphic designer hehe
  8. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Memtest86
    Page is fairly self-explanitory...
  9. fathazza
    fathazza Freed on Probation
    20 May 2002
    i think winxp has some serious known issues with some older via chipsets if thats what ur on.
  10. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Edit: WTF just realized this was the wrong thread :lol:
  11. meryan00
    meryan00 What's a Dremel?
    16 Nov 2002
    the memory may not necessarily be the issue...i had the same issue yet it ended up being that the hard drive was failing...check your drive also with the memory...i had some other issues resulting in the same problems but i dont remember what the issues were at teh moment:thumb:
  12. malMethod
    9 Jul 2003
    well, i took everything out of my comp, and put it all back in. i dont have the bluescreen anymore, but now i have an error saying that NTFS.SYS is either corrupt or missing. i have winxp home on the way -- should be here tomorrow :-D
  13. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    you have a driver problem. i learned that a BSoD is aways a software issue. in your case it might be driver. i got that ntfs error thing once when i was overclocking. i tryed to get my comp going at 4.5 ghz and i was like OMG and i had to reinstall because it coruped somehow. just my luck.
