Modding Window FX
Discussion in 'Modding' started by will., 2 Mar 2005.
  1. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Does anyone know of a good way of creating an etched effect on the entire surface of a window?
    What i was thinking of was making a window with the entire surface etched and in the center, a logo of some kind recessed into the plastic. Then I would use LED's to light up the plastic from the sides. Beacause of the way light travels in plastic you would not see the light in any other areas than the logo where the light would break as it hits the edges of the logo.
    I have access to a cnc machine and would easily be able to create the logo, but i don't know how to create the etched effect... I would reather not use a sticker.
    I was thinking about trying to get it sand blasted... would this work?
    The only other way i can think of is to sand paper the whole surface, but this would give a grained effect from whichever direction i have sanded in...
    If anyone has done any of the things i have described above i would love to see the effects, thanks..
  2. GlassX
    GlassX What's a Dremel?
    11 Jul 2004
    Go to home depot.. they have "frosty" coating (paint section). It works well on plexi and comes in tons of colours.
  3. will.
    2 Mar 2005
    th problem with only altering the surface is that the light passing through will not refract of the surfaces and so the lighting will not work.
    I plan on trying each method out on scrap over the easter holidays, i'll post some pics up then.
  4. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Sand blasting will work. I believe that is what _ferry_ did for his mousepad which turned out awesome. Edit: link, look near bottom
  5. will.
    2 Mar 2005
    Thats the exact effect that i want on my case's window!!!
    PM'ing him now!
    Thanks loads.
  6. Gumbatron
    Gumbatron What's a Dremel?
    18 Nov 2004
  7. KidModder
    KidModder What's a Dremel?
    22 Dec 2004
    Avner did a good window "FX" on his Deus Ex mod.
