Modding window plastics
Discussion in 'Modding' started by VadimtheConqueror, 15 Jul 2002.
  1. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    a question about windows.
    what kind of plastic makes for a good window, and about how thick should it be?
  2. PsychoGremlin
    PsychoGremlin What's a Dremel?
    15 Jul 2002
    plastics
    The stuff we (Vadim and I) plan on using is stuff i found lying around at work. I'm not entirely sure what brand of plastic it is, but it's somewhere between 1/4 and 1/3 of an inch thick, and it has blue protective plastic covering it up, so it's somewhat high quality.
    Should the plastic be thicker? it's covering an area of 14"x14" (on my box, dunno about Vadim's) so is there a recommended thickness for those dimensions, or does it not really matter all that much?
  3. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    That should be thick enough for that purpose.
    If you were building a case out of it, nothing less than .25" will do, but for a window you can get pretty thin without any worries.
  4. VadimtheConqueror
    10 Jul 2002
    thanks, also, turns out it's plexi
  5. socketman
    socketman What's a Dremel?
    9 Apr 2002
    i used lexan. great stuff.
