Windows window shuts down problem
Discussion in 'Software' started by samspiers83, 10 Apr 2005.
  1. samspiers83
    samspiers83 What's a Dremel?
    10 Apr 2005
    my pc rarly shuts down by its self.....it does sometimes but it usally just stays at "saving your settings" and then doesnt get any further that that...some 1 help me please?
  2. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    What operating system are you using?
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    He's using Windows Xp pro.
    (I know the guy personaly)
  4. samspiers83
    10 Apr 2005
    yes i am using windows XP pro...thanks rob :D
  5. ouija
    10 Nov 2002
    Are you running a Pre-SP1 installation of Windows XP? If so, this was a known problem fixed in SP1.
  6. samspiers83
    10 Apr 2005
    no i am running windows Xp service pack 2
  7. ouija
    10 Nov 2002
    Okay, that's fine. There are several other issues, mainly related to various hardware, which can cause Windows XP to hang at the "saving your settings" dialog box. Can you post the specs of your machine please, if you know. It might also help if you would post the make of components like your motherboard and graphics card.
    Also, if you do leave your computer for a long time does it eventually completely shut down?
  8. samspiers83
    10 Apr 2005
    sorry i dont actually no alot about my machine.
    all i know is that its amd athlon(tm) Xp 2400+, 2 ghz, 256 mb of ram. soon to be 768mb of ram :D
  9. ouija
    10 Nov 2002
    And does the computer eventually shut down if left long enough?
  10. samspiers83
    10 Apr 2005
    no... i used to turn it off at night and then when i wake up in the mornin its still on and says "saving your settings" so i dont think it does
  11. ouija
    10 Nov 2002
    Before I check any of your hardware that can be the cause, do you use the Windows XP welcome screen? Try turning it off in the control panel and see if your PC shuts down properly
