Windows Windows 10 VGA driver issue - HDMI
Discussion in 'Tech Support' started by Xir, 30 Oct 2015.
  1. Xir
    Xir Modder
    26 Apr 2006
    My computer is driving me nuts, but I think I may just be missing a setting.
    I have a weird HDMI-out problem.
    I reinstalled Win10, and HDMI-out doesn't work.
    So I downloaded the recommended driver from the Laptop manufacturer and installed it.
    HDMI-out works.
    To finish the the install I need to restart.
    HDMI-out is dead.
    So I went to Device Manager, deinstalled it, restarted,and reinstalled it.
    No HDMI-out
    Device Manager again, it offers me to update the driver automatically.
    HDMI-out works. I watch a movie.
    I restart.
    HDMI-out is dead. :wallbash:
    Device Manager offers me to use "last working driver", I click okay.
    HDMI-out works!
    I restart.
    I restart.
    HDMI-out works!
    I restart.
    Do you start to see a pattern yet? :D
    Anyway I went to automatic update settings, and set it to no automatic updates (as I suspect it to update when restarting), but the behaviour stays the same.
    It's driving me nuts.
    HELP!!! :D
    It's a Celeron N2940 based netbook (Tablet---2in1) with integrated graphics and Win10 64bit, so nothing extraordinary.
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    What happens if you try the drivers direct from Intel (I'm fairly sure those are the right ones)?
  3. Xir
    Xir Modder
    26 Apr 2006
    The same.
    The Windows update loads the Intel drivers, and I've also installed them directly.
    I've also tried the last Win8.1 drivers, same thing.
    I've also installed and tried the Intel Driver Update Utility:
    The only change I can get in this behaviour ist that it stopped outputting to HDMI completely, even after changing the driver.
    I reinstalled windows since then, now I'm back to the behaviour I posted above, HDMI-out works after changing the driver, but stops after restart.
  4. Xir
    Xir Modder
    26 Apr 2006
    No ideas what might be causing the changes after reboot?
